User Friendly CNC Controls, Turn-key professional service
for Milling Machines, Lathes, Routers, Plasma, & special applications
  CENTROID CNC Retrofits Milling Machines, Lathes, Machining Centers, Routers, and more..
Click on photos for more information about that type of machine.
Bridgeport Boss 5 with Centroid M400 CNC retrofit Machining Center control upgrade kits for all kinds of ATC machines. CNC Router retrofit control system for all kinds of CNC routers.
Retrofits for CNC Machining Centers: Leadwell, Bridgeport,
Pratt&Whitney,
Brown&Sharp, and
many others
CNC Router Table Retrofit kits for: Standard Router, Thermwood, Camtech, Multicam, AXYZ, and many others.
CNC Retrofits for all Bridgeport CNC Machines. All Boss knee mills, DX-32's, Torque Cut, Interact 412, Discovery 300, 308 more..
  Proto Trak Retrofit   Hardinge CHNC/HNC CNC retrofit upgrade packages.
Mori Seiki CNC retrofit kits for SL series.
Mori Seiki SL series turning centers, CNC Retrofit   CNC lathes: Prototrak
Mazak quick turn,
LeBlond, Cincinnati, Warner Swayze and more
    Hardinge HNC and
CHNC retrofits.
New lower Price!
Hardinge HLV manual and CNC on one machine! Engraving and Jewelry Making, Ring and coin patterns and dies.     Manual and CNC control on the same knee mill.
Hardinge manual to CNC retrofit conversions for HLV-H and others
Compact milling machines: Engraving, Medical, Jewelry making, EDM electrodes new and CNC Retrofits.
Manual to CNC retrofit conversions for Bridgeport type knee mills
Huge Horizontal Jig Bore machines!   Vertical Lathes with C axis! Shizuoka CENTROID M-39 CNC Retrofit in 8 hours!
  Vertical Lathes: CNC Retrofits for : Monarch, Niles, G&L. C axis!
CNC Retrofits for Horizontals Boring Mills and Jig Mills. Delveig, G&L and more.     Shizouka CNC knee
mill retrofits
Fanuc Lathe Retrofit
Fanuc® CNC Retrofits!
CENTROID directly runs your Fanuc drives and motors.
Directly control your Fanuc Yellow Cap and Black cap servo motors and drives with a CENTROID CNC control! Up to 8 axes.
CENTROID's new CNC CPU commands your existing Fanuc drives in motors.
With the CENTROID Fanuc retrofit system, there is no need to rewire or replace the motors and drives. Save time and money and get better performance with much easier programming and operation. The CENTROID Fanuc Retrofit system makes an old machine tool into a real money maker for less than the cost of repairing the old Fanuc control!
Keep the good Fanuc servo drives and motors and only update the old computer operator interface. click here for more info...
CNC Retrofit images: Milling machines, Lathes and Routers equipped with a CENTROID CNC Retrofit. click here for more image galleries...
CNC PC minimum Performance Requirements
Factory CNC remote support via "Team viewer"
Factory CNC support via email or phone
Site content ©2004-2023 CENTROID Corporation. All rights reserved. Terms of use.
