The CENTROID KP-3 CNC Touch probe is designed for Probing (part setup, zero location setup, and CMM type location and measurement of part geometry), component/fixture/work piece setup, inspection and 3D or 2D digitizing/surfacing. The KP-3 CNC Touch probe is made in USA with patented technology. Centroid has developed the KP-3 from its 30 years of probe building knowledge to achieve this affordable, accurate, robust design. Commonly used on Milling Machines, Machining centers, Routers and Turning centers. The KP-3 is a state of the art Kinematic touch probe and is compatible with most any CNC control that has an input for Probes. Acorn to KP-3 connection is a simple 4 wire hookup just follow the schematic. CNC software configuration is simple one button press with the pre configured preset for the KP-3 using the Acorn Setup Wizard. Also compatible with Mach3/4, WinCNC, LinuxCNC, Pathpilot and others. |
An invaluable tool for a wide variety of CNC machines. Quickly, easily and accurately setup tool heights with a push of a button. Now setting up tools is a joy not a chore. No more gauge blocks, no more paper, no more repeated measurements. Save time and increase accuracy. Once you start using a tool setter you'll wonder why you waited to purchase this time saving tool. CENTROID manufactures two types of Touch Off devices, the TT-1 which is a conductive design and the TT-2 and TT-4 which are mechanical designs great for spindles with non conductive bearings (ceramic) or tooling that doesn't conduct (diamond) |
More info on the TT-4 is here. |
Set
up your tools in a quarter of the time it would normally take!
If you often machine short-run parts and are always setting up
and tearing down for a new job, the TT-1 Auto tool set will save
you tons of time while more accurately setting your tool height
offsets. With the TT-1 you can create more parts per hour since
the tool setup is so much faster. You'll even save time when you
have to replace a dull tool with a new one in the middle of a job.
The TT-1 is completely automatic. Press "measure" and
the tool will automatically touch off the TT-1 and set the tool
height offset in the tool library. Requires conductive tooling and spindle.
Link to TT-1 Brochure
TT-1 auto Tool Setter (Part #10220) |
We stock common sized probe styli. The KP-3, DP-4 and the DP-7 use the same styli thread mount, so these styli will fit the KP-3, DP-4 and DP-7. click here to download the Probe Tip Size and Price sheet. |
