Centroid "AcornSix" Step and Direction CNC Controller kit
This is a legacy page, to view up-to-date information and pricing please visit the AcornSix Page on ShopCentroidCNC.com
The AcornSix CNC system has been engineered, built, and tested at our Centroid facility in the USA. All units ship ready to run after thorough testing and quality control.
AcornSix CNC controller kit
Add to Cart
Centroid Acorn CNC controller kit part #15136 includes:
- AcornSix CNC control board
- Qty. 2 Acorn Plug and Play Relay 8 Modules
- Dual power 5 VDC and 24 VDC logic power supply
(50/60 Hz 100-120 VAC and 208-240 VAC input power)
- 15’ Shielded Ethernet cable
- Riser Mounting Pan
- Centroid AcornSix BETA v4.99 CNC12 for CNC Mill, Router, Lathe download
- Touch Screen Responsive Operator Controls
- DIY self service CNC support thru Centroid Community CNC Forum which is Centroid Technician monitored and maintained.
- Optional Factory Direct Technical Support
(Note: A 1920x1080 wide screen LCD Display is required and a Touch Screen is recommended.)
Included with the AcornSix controller kit is a mounting riser pan. The riser pan allows easy 4 hole mounting of the AcornSix to the back panel while allowing other wires, power supplies, relays etc to be mounted underneath it for space savings in the electrical cabinet. The mounting pan is not required so if you don't want to use it you can mount the AcornSix using the through holes in the board itself.
Centroid AcornSix CNC Software License Upgrades
AcornSix Mill "Pro" CNC Software license
Add to CartUpgrade to Centroid Acorn Mill "Pro" CNC12 from the Free version that is included with each AcornSix kit. *Lifetime License.
- Unlimited G-code file size
- 4th axis motor pairing with any other axis
- 4th axis G-code moves
- Full version of Intercon conversational programming
- 4th axis conversational programming
- Rigid Tapping
- Six WCS locations (G54 thru 59)
- Tool Library with 200 tools
- Unlimited Auto Tool Measure
- Full set of menu driven Probing cycles (Bore, Single Edge, Web, Slot, Inside corner, outside corner)
- BCD Tool Changer Output
- WMPG-6 support
- All features of the CNC12 Free are included
After purchase, the License will be sent via E-mail delivery. M-F 8-5 EST USA
Each Acorn Software License is specific to a single Acorn board.
If you are purchasing a license for a previously ordered Acorn kit please email a report.zip file to diysales@centroidcnc.com to expedite delivery.
AcornSix Ultimate CNC software license
Choose Mill, Router, or Lathe.
*Lifetime License.
Full feature set of Digitizing and Probing capabilities for your Mill or Router
- Offline Intercon USB key, run Intercon on any Windows PC
- 2D and 3D Digitizing, Grid, Radial, Contour. (Mill and Router)
- Digitizing cycles is easy push button menu driven operation. (no macros needed!) Mill and Router.
- Export Data to Cad/Cam (Mill and Router)
- Auto G code generation (Mill and Router)
- Unlimited Auto Tool Height Measurement (Mill and Router)
- Full set of menu driven Probing cycles (Bore, Single Edge, Web, Slot, Inside corner, outside corner) (Mill and Router)
- Eighteen WCS locations (G54 thru 59 plus 12 more)
- Menu driven Auto Coordinate System Rotation with Probe (Mill and Router)
- Works with Centroid KP-3 Touch Probe or any other Contact probe.
- All features of the CNC12 Free and Pro are included
Centroid AcornSix "Pro" Lathe CNC software license
AcornSix Lathe "Pro" CNC software license
Add to CartUpgrade to Centroid Acorn Lathe "Pro" CNC12 from the Free version that is included with each Acorn kit. *Lifetime License.
- Threading (requires spindle encoder)
- Rigid Tapping (requires spindle encoder)
- Feed per revolution (requires spindle encoder)
- Constant Surface Speed
- 99 Tools
- Full version of Centroid Lathe Intercon Conversational Programming software:. Auto profile cleanout, grooving, cutoff, chamfer, turning, end face turning, threading and more.
- Unlimited G code file size
- WMPG-4 and WMPG-6 support
AcornSix Router Pro CNC software license
*Lifetime License
All the CNC features of Mill Pro but with a Router specific Virtual Operator Control Panel and the corresponding Router specific macros
"Ultimate Plus": 6 axis simultaneous interpolated motion CNC software.
*Lifetime License. Part# 15263
Includes all the features of Ultimate, PLUS 6 axis simultaneous interpolated motion CNC software.
AcornSix can command all 6 axis drivers with or without this option. This option allows: Simultaneous Coordinated Interpolated motion of individual axes involving 5 or more axes which is a regulated technology by the US government. (If you are outside the US we will provide and ask you to sign two documents, a letter of assurance and a letter of certification for our records).
Most users do not require this feature. Don't confuse True interpolated 5+ axis motion with simply having 5 or more drive ports on the CNC control board that all can command and move 5 or more axes. AcornSix without this 6 axis simultaneous software is considered a 4+2 system. Which is: Fully interpolated motion for ANY four axis in ANY combination at ANY given time. For instance XYZW, XWAB, ABCW, ZWAB, XYAB, ZYAB, etc..
Acorn "Start Here" Web Page with requirements and How-to Videos.
Acorn CNC controller Hookup Schematics (type in "AcornSix" in the search bar on this page to see all AcornSix hookup schematics)
Centroid AcornSix CNC12 Latest Software Download (a powered up connected AcornSix is required to run this CNC software)
AcornSix Draft Users Installation Manual.(draft)
All Acorn Documentation (a list of All Acorn related documentation)
Centroid CNC control board Solid Models
CNC Community Support Forum (Free Tech Support!)
Acorn CNC controller buyers FAQ
Centroid AcornSix CNC Mill, Router and Lathe Software Levels
| Features | AcornSix Free v5.0+ | AcornSix Pro v5.0+ | AcornSix Ultimate v5.0+ |
| Version | Free Version (no license required) | Mill Pro, Lathe Pro, Router Pro License | Mill, Router Ultimate License |
| User Configurable Touch Screen Virtual Control Panel (aka VCP) | Included | Included | Included |
| Mill (Router uses Mill) and Lathe Intercon Conversational programming | Limited to 20 blocks of conversational | Unlimited | Unlimited |
| Wireless MPG Pendant WMPG-4 or WMPG-6 support | Not included | Included | Included |
| G-code program size | Limited to 50Kb G-code file size | Unlimited G-code file size | Unlimited G-code file size |
| Work Coordinates Systems (WCS) | One (G54) | Eighteen (G54-G59 plus extended WCS) starting with v5.08 |
Eighteen, (G54-G59 plus extended WCS) |
| Menu driven Probing cycles | Center of bore | Complete Set of menu driven probing cycles. Bore, Boss, Slot, Web, Inside Corner, Outside corner, Single edge find, find angle, auto probe for CSR | Complete Set of menu driven probing cycles. Bore, Boss, Slot, Web, Inside Corner, Outside corner, Single edge find, find angle, auto probe for CSR |
| Menu driven Digitizing cycles | Grid, Radial, Contour, Wall following, limited to 2500 points | Grid, Radial, Contour, Wall following, limited to 2500 points | Unlimited point Grid, Radial, Contour, Wall following |
| Auto Tool Height Measurement | Unlimited auto measure on: Reference Tool & Tools 1,2,3 |
Unlimited auto measure on all tools. | Unlimited auto measure on all tools. |
| Support for "Probe App" by swissi | No | Yes | Yes |
| Coordinate System Rotation | Yes | Yes | Yes |
| Auto find CSR with Probe | No | Yes | Yes |
| Manual find CSR with Probe or Wiggler | Yes | Yes | Yes |
| Manual enter angle for CSR | Yes | Yes | Yes |
| Tool Library | 10 Tools | 200 Tools, (99 Tools Lathe) | 200 Tools Mill, (99 Tools Lathe) |
| Sub Programs and Macros (M98 & G65) Write your own custom macros, many uses |
| Cutter Compensation G41/G42 | Included | Included | Included |
| Backlash Compensation | Included | Included | Included |
| Screw compensation (laser or manual!) | Included | Included | Included |
| 3 axis simultaneous | Included | Included | Included |
| 4 th Axis linear or rotary conversational programming. | limited to 20 blocks of Intercon | Unlimited | Unlimited |
| Operate as a 2 axis CNC with Manual Quill | Included | Included | Included |
| Operate as a 2 or 1 axis CNC control | Included | Included | Included |
| Any axis can be Linear or Rotary | Included | Included | Included |
| Slave Linear to Rotary axis or vise verse | Not Included | Included | Included |
| Inverse Time Motion | Included | Included | Included |
| Supported Axes Labels |
X, Y, Z, U, V, W, A, B, C Mill / Router / Plasma |
X, Y, Z, U, V, W, A, B, C Mill / Router / Plasma X, Y, Z, C, A, B Lathe |
| Multi Axis Lathe interpolated motion | No | Included | Included |
Spindle Encoder feedback,w/ RPM display |
| Spindle RPM display with single pulse per rev sensor | Included | Included | Included |
| Axis Scale input for position DRO display | Included | Included | Included |
| Axis Scale input for position correction | No | No | Included |
| XY axis deskew | Included | Included | Included |
| Mill Rigid Tapping | Not Included | Included | Included |
| Lathe Threading | Not included | Included | Included |
| Lathe Automatic CSS | Not Included | Included | Included |
| Lathe Rigid Tapping | Not included | Included | Included |
| Lathe Automatic Tool Measurement | Unlimited auto measure on: Tools 1,2,3 |
| Lathe C axis | Not Included | Not included | Included |
| G81 drilling cycles | Included | Included | Included |
| Compression Tapping Gcode Cycles | Included | Included | Included |
| Mill G-code scaling and mirroring | Included | Included | Included |
| True G-code backplot graphics | Included | Included | Included |
| Run Time Program Graphics | Included | Included | Included |
| Smart Search (stop and restart at any point) | Included | Included | Included |
| Backlash compensation | Included | Included | Included |
| CNC Configuration Wizard | Included | Included | Included |
| Menu driven Part and Tool setup menus | Included | Included | Included |
| Intercon Teach Mode | Limited to 20 blocks of Intercon | Unlimited | Unlimited |
| Intercon Drilling cycles: Drilling, Deep Hole, Chip Breaking | Limited to 20 blocks of Intercon | Unlimited | Unlimited |
| Intercon Pocketing: Circular,Rectangular, Irregular | Limited to 20 blocks of Intercon | Unlimited | Unlimited |
| Intercon Contouring | Limited to 20 blocks of Intercon | Unlimited | Unlimited |
| Intercon Threadmilling | Limited to 20 blocks of Intercon | Unlimited | Unlimited |
| Intercon Conversational Compression Tapping | Limited to 20 blocks of Intercon | Unlimited | Unlimited |
| Intercon Auto Connect Radius | Limited to 20 blocks of Intercon | Unlimited | Unlimited |
| Intercon Lathe Cycles. Auto profile cleanout, grooving, cutoff, chamfer, turning, end face turning, | Limited to 20 blocks of Intercon | Unlimited | Unlimited |
| Intercon Math/Geometry Help | Limited to 20 blocks of Intercon | Unlimited | Unlimited |
| Intercon DXF Import for Mill and Router. | Yes, Limited to 20 blocks of Intercon | Yes, Mill, Router | Yes, Mill, Router |
| Operate in Millimeter or Inches | Yes | Yes | Yes |
| XY Diagonal Jogging | Yes | Yes | Yes |
| 4th axis Jogging | Yes | Yes | Yes |
| Software Axis Pairing (pair 4th axis any other axis in software) |
No | Yes | Yes |
| Two sets of software Axis Pairing Example: First axis paired with 4th, Second axis paired with 5th. |
No | Yes | Yes |
| Auto Squaring of Software Paired axis with auto homing | No | Yes | Yes |
| Hardware Axis Pairing | Yes | Yes | Yes |
| 4 axis Simultaneous G-code moves: | No, "Free" is limited to 3 axis of simultaneous moves with single axis 4th,5th,6th axis moves. | Yes, 4 axis simultaneous movement with full interpolation. (interpolated moves for any four axes in combination with any others including paired axes.This is 4+2*) |
| Simultaneous 5 axis drive moves with one paired axes | No, "Free" is limited to 3 axis of simultaneous moves with single axis 4th,5th,6th axis moves. | Yes, 4 axis simultaneous movement with full interpolation.(software paired axes are considered 1 axis as it has one label) This is 4+2*. |
| Simultaneous 6 axis drive moves with two paired axes | No, "Free" is limited to 3 axis of simultaneous moves with single axis 4th,5th,6th axis moves. | Yes, 4 axis simultaneous movement with full interpolation.(software paired axes are considered 1 axis as it has one label) |
| non paired (individual axes) 5 and 6 axis Simultaneous G-code moves: | No, "Free" is limited to 3 axis of simultaneous moves with single axis 4th, 5th, 6th axis moves. | Requires purchase of 6 axis simultaneous interpolated motion software. | Requires purchase of Ultimate Plus. |
| BCD Tool Changer output | No | Included | Included |
| Rack Mount ATC setup Wizard | Yes | Yes | Yes |
| ATC Programs for Lathe Turret | Yes | Yes | Yes |
| CNC Setup Wizard with auto PLC program generation |
| CNC12 Color Picker (create,save and share CNC12 software color themes) | Included | Included | Included |
| PLC Detective Software | Included | Included | Included |
| Use one input for all axis Homing an or Limits | Included | Included | Included |
| Laser Engraving and Cutting | Yes | Yes | Yes |
| PWM output for Laser power | Yes | Yes | Yes |
| PWM output for Spindle speed control | Yes | Yes | Yes |
| Laser power Velocity modulation | Yes | Yes | Yes |
| Spindle VFD +-10, 0-10, +- 5, 0-5 VDC analog output | Yes | Yes | Yes |
Optional AcornSix Scout Encoder Expansion Kit #15330
Add to CartThe Centroid AcornSix Scout Encoder Expansion Kit adds six additional encoder/scale/mpg ports for a total of nine to a AcornSix based CNC controller. The additional encoders ports can be used for encoder input, scale input, and MPG input. Connects to the AcornSix via a standard shielded Ethernet cable which is included. Scale input with the AcornSix can be used as a DRO position readout OR for closed loop position correction.
- Add six additional Encoder or Scale ports to an AcornSix
- Plug and Play, Encoder Expansion board to AcornSix uses a standard shielded ethernet cable (included)
- Typically used for multiple MPG or Scale inputs.
- User configurable
Optional SCOUT PLCEXP1616 i/o expansion kit for the Acorn CNC controller
Add to CartThe PLCEXP1616 is an input and output expansion board designed to be used with the AcornSix CNC controller using the ethernet cable SCOUT communications protocol. Each PLCEXP1616 board adds an additional 16 optically isolated inputs and 16 relay isolated outputs to the AcornSIX CNC system, up to five PLCEXP1616 boards can be added to an AcornSix system for a total of 96 inputs and 96 outputs. Three different input device voltages can be used: 5 volts, 12 volts and 24 volt. AcornSix and PLCEXP1616 input device voltages are mix and match capable and are selectable via bank of four of inputs at a time with the provided plug-in SIP (Single In-line Pack) resistors. The default input voltage is 24 VDC (no SIP installed).
The PLCEXP1616 has Din Rail mounting holes and Standoff mounting holes to allow the DIY installer a wide variety of mounting possibilities. Requires 24 VDC logic power of at least 1amp rating.PLCEXP1616 Spec Manual.
PLCEXP1616 Kit part #14575 includes:
1.) PLCEXP1616 Board
2.) 6 foot shielded Ethernet cable
3.) Qty 4 220 Ohm SIP resistors for 5 volt input
4.) Qty. 4 1k Ohm SIP resistors for 12 volt input
Optional SCOUT CNC Operator Control Panel/Pendant part #14612
Add to Cart
CNC Operator control panel
If you like pressing buttons rather than touching a screen use this tough Centroid Operators control panel. Its made in USA and uses stainless steel dome buttons that provide positive tactile feedback. Constructed of steel the bezel can mount into pendant box or flush to any cut out. The high quality overlay made from durable grease and chemical resistant special flexible plastic designed for the machine shop environment. Use as a replacement for the VCP (virtual control panel (touch screen)) OR use in conjunction with the VCP. The VCP and the control panel are user configurable so they can be setup to match functionality.
The operator panel can be installed several different ways:
1.) Mount in a CNC console
2.) Machine Panel Mount (console is part of the machine tool)
3.) Corded Hand Held with 16' cord, steel construction, rubber handles and magnets on the back.
A lower cost ($0) alternative to this piece of hardware is the software based Touch Screen Virtual Machine Control Panel (VCP). The VCP allows the functionality of this Hardware based Operators Control Pendant when using a Touch Screen LCD as the CNC control display. The touch screen VCP is included with Centroid CNC control software CNC12 and can be used without or in conjunction with this hardware based Operator's Control Pendant.
Longer cords up to 50' are available call for quote or just use the Wireless MPG for long distance applications.
Use your own PC OR purchase a Centroid CNCPC
- Preloaded with Windows 10 and pre-configured for CNC PC duty
- Preloaded Centroid CNC software with G code Editor,
Intercon, Stock PLC programs, Acorn Install Wizard, Touch Screen
Operator Control panel.
- Touch Screen
- Wifi, Ethernet, webcam with mic, card reader, usb ports
- Powercord, Keyboard, Mouse
- Centroid tested and pre qualified to work with Centroid CNC controllers
- Compatible with Acorn, Oak, and Allin1DC
- Model, Specifications and COLOR may vary.
Note: There are NO VESA mounting holes on this unit.
Planning to build or use your own PC as a CNCPC? Be sure the PC meets the Centroid CNCPC minimum requirements found here. The Centroid CNC software runs on any Windows 10 PC that meets the requirements.
- If you plan to build your own CNCPC follow the recommendations here.
- If you plan to buy your own PC we recommend the Intel NUC (be sure to purchase a NUC that meets the Centroid minimum pc requirements) and a 1920x1080 16:9 aspect Touch Screen monitor
- Centroid also offers for purchase CNCPC's with preloaded and pre configured software
Centroid NUC CNCPC
- Allows use of any size and type LCD Touch screen. (1920x1080 recommended) or regular LCD monitor.
- Higher Performance PC specifications than the the above Allin1PC
- Intel SSD for the best performance
- Preloaded with a licensed copy of Windows 10 and Windows is pre-configured for CNC PC duty
- Preloaded Centroid CNC12 software Mill and Lathe, Free version
- Pre configured Notepad ++ G code Editor
- Intercon Conversational
- Centroid CNC setup Wizard
- Touch Screen Operator Control compatible
- Intel processor, SSD (solid state drive)
- Display port, HDMI, Ethernet, USB
- Centroid tested and pre qualified to work with all Centroid CNC controllers
E-Stop Button with 2 contact closures #14534
- Industrial quality reliable Emergency Stop Button with two switches.
- Two contact closures for two estop circuits
- Use just one contact closure or use both
- For use with the Acorn CNC control board.
WMPG-6 (PDF download)
International shipping is calculated during checkout.
Requires CNC12 v4.16+ and a Pro License
Take the control to where the work is! A game changing tool, the Centroid Wireless MPG handwheel CNC Control pendant allows the operator to conveniently and precisely set up jobs and tools remotely.
Plug and Play with Centroid CNC12 Pro Acorn CNC software and CNC12 for Oak, Red Oak and Allin1DC with the USB MPG software plug-in.
Simple and fast setup. Plug in the included USB transmitter/receiver and start using it! Perfect for all types of Mills, Lathes, Routers and other specialty CNC machines. click here for more info.
KP-3 CNC touch probe
Part, Vise and Fixture Probing: Automatically Set Zero points fast and accurate.
KP-3 Acorn kit part# 14946
- KP-3 probe
- 2.5 mm x 40mm carbide stem, ruby tipped stylus
- Stylus wrench
- KP-3 to Acorn cable
- KP-3 Users Manual
- KP-3 to Acorn schematic
Mill, Lathe and Router use. Kinematic Design works with both conductive and non conductive tools and spindles. Quickly and accurately setup tool heights in the tool library with a push of a button. The CENTROID TT-4 automatic tool height offset touch probe is plug and play with all Centroid CNC controls. Eliminates gauge blocks, paper, and repeated measurements. Save time and increase accuracy. Fully integrated into the CNC control tool library menu, just select the tool and press auto measure to set the tool height automatically. Makes measuring all types of tools faster and more accurate. Find the longest insert in a multiple insert tool quickly. Once you start using the TT-4 you'll wonder why you waited to purchase this time saving tool. Measure just one tool or a whole group of tools at once. Can also be used in the middle of a job to measure a replacement tool. Integrated with an Automatic tool changer for batch tool measurement. The TT-4 is based on KP-3 touch probe technology and is a robust kinematic design and works with all spindles even ones that with non conductive bearings (ceramic) or tooling that doesn't conduct (diamond).
TT-4 Acorn kit part# 15135
- TT-4 Tool touch probe
- Carbide Touch surface
- TT-4 to Acorn cable
- TT-4 to Acorn schematic
Conductive TT-1 CNC Tool Height Measurement Device
- Set Tool Lengths automatically
- Ultra accurate conductive design
- Save time, increase accuracy
- Magnetic base or hard mounts (T-nut or Shank)
- Works w/ CENTROID & most other CNC’s
- Easy to achieve high precision measurements
- Designed for milling and lathe applications: Kneemills, Bed mills, Machining centers and Routers,
Lathes and Turning centers
- In process tool reset for worn out or broken tools
- Requires conductive tools
- Serviceable unit
- Auto cable detection
Offline version of INTERCON Mill, Lathe and Plasma (in beta) conversational programming, for use with Windows desktop PC*
Add to Cart
- For those that do not want to use or learn a CAD/CAM system to make CNC parts.
Program parts in the comfort of your office.
- Program while the machine is running a job.
- Easy part program transfer from your PC to the control via LAN or USB.
- True G-code backplot graphics, see exactly what the machine toolpath will be.
- Use on the same PC as your CAD system.
- A USB Keylock allows user to install software on as many computers as they want.
- Offline programming USB keylock is shipped the next business day.
- Works with Windows 7/8/10/11*
- Manual with tutorial examples see Mill Chapter 10, Lathe Chapter 8
- Download offline conversational programming software here
The offline programming software runs without USB keylock but limited to 20 lines of Intercon. Plug in the USB keylock for unlimited conversational programming operation. Installation instructions here.. and a video showing installation of offline Intercon.
Replacement Parts
REPLACEMENT Acorn Relay Board and Ribbon cable
If you are purchasing a new AcornSix kit, you do not need to purchase this item.
The Acorn Relay Board Kit (part #14734) Includes:
- Acorn “8 Relay Module”
- Ribbon Cable
Centroid Acorn CNC controller reviews
"Looking to order boards and other parts from you this week. I've got to admit - SO NICE having a board and software made by the same company. No plug ins from other places and the headaches. Literally followed the video and the motors were turning by the time it was done.
- Revy
"After dealing with Mach 3 and LinuxCNC for years, I must say Centroid is Light years ahead. Up and running bench test in a matter of minutes instead of days as with those other products. There is much to learn about Centroid but I am confident it is a very solid product. I can't find the words to properly describe the difference."
- Makeron
"My son came to me and said that the students in his high school woodworking class could not finish their projects due to their CNC router is broken. Well I couldn't let this be and in less than an hour, I installed a acorn on their router and all the students were able to finish their projects. I donated the board to the school so they could continue to use the router and many students will be able to familiarize themselves and use the Centroid control. Thank you Centroid for making such an awesome easy to use and install product. Keep up the good work!"
- Extreme industrial
I have to say a big THANK YOU to Centroid for providing the best value in DIY CNC on the market today. I just completed the upgrade of my CNC router table to Acorn and couldn't be happier! Followed the schematics for the GeckoDrive 203V (only thing I kept from my old controller) and everything just worked without any issues. Watched a lot of video's that provided almost everything I needed to get my machine working. I saved so much money over upgrading to Mach4, Smooth Stepper and PMDX boards that I had planned for my initial upgrade that I bought a touch screen monitor, wireless pendant and upgraded to Mill Pro. The pendant is just amazing to use. I feel like I have a professions system now! Not sure how you can sell the entire acorn kit for the price you do, but thank you for providing this to the DIY community.
- cnc_jim
Yesterday, I received a model 4 Acorn and an extra relay board for my model 3 Acorn that I bought almost a year ago. Opening that package reminded me of the care and concern that Centroid has for its customers. The power supply was pre-wired for the Acorn. The instruction sheet is comprehensive. The backside of the instruction sheet that shows a connection schematic that should make initial connections fool-proof. I just noticed that even those schematics are printed in color. (My eyes have serious problems.) The new schematics that Keith notified us of have fixed all of the connection problems that I've experienced with ClearPath servos, Gecko G203 drives, and Leadshine (clone) drives. Those problems were not Centroid's fault. (The older schematics followed wiring diagrams from other manufacturers that were somewhat lacking. I've read Teknic's manual carefully about the fault signal. The older schematics followed the Teknic manual. Keith and Gary solved that problem months ago, but because I had a work-around, I didn't carefully read the revised schematic that Centroid published months ago.) I was able to work around those problems; but the new schematics make those work-arounds obsolete. It amazes me that Centroid is willing to spend money on so many do-it-yourself motors, drivers, spindles, VFDs and other non-Centroid products, test those products, draw up schematics to use those products and still sell the Acorn for $329 with the amazing Centroid software.
Next, the forum along with YouTube videos are great. Keith, Marty, Gary and Franco not only show how to use the Acorn, but teach general principles about CNC machining. Late last night when I couldn't sleep, I watched a video where Keith showed how to use a vertical mill. The video contained everything that anyone would need to see how to use Centroid products to make their equipment work. Clicking on "Acorn User Videos" from the Acorn page shows a list of videos that show how to use the Acorn. Going on YouTube and searching "Marty CNC" brings up Marty's channel with a comprehensive list of how-to videos. Searching "Gary Campbell CNC" brings up Gary's channel and his expertly produced videos. (Gary and I go back decades to my Shopbot days when I constantly used his advice to solve my problems.) Clicking on "Centroid CNCKeith" brings up Keith's videos. His knowledge and easy-going style should make anyone comfortable in trying an Acorn. One of his videos was with "MecTechMike". Mike's mill and lathe conversions should impress everyone. He surely impressed me and gave me ideas that will take at least a year to try. There are many, many others who have taken the time to post videos showing how they use the Acorn and other Centroid products.
The forum is invaluable. Questions are answered expertly (in most cases). Since I tend to be disruptive in some of my posts (unintentionally - I like to think outside the box and try things that might seem to be controversial), I expected harsh feedback or even censoring, but I've been treated with respect and courtesy. More, importantly, by reading what others are doing, I get ideas that would take a life-time to implement.
Thanks Centroid and thanks to all of you in the Acorn community for your help.
Featured Youtube Videos
