ShopBot and AVIDCNC Acorn CNC Retrofit upgrade kits by GCnC
Industrial Quality CNC retrofit upgrade kits for all systems made by ShopBot for the PRT and PRS and all AVIDCNC models. Completely transforms the machine into a reliable work horse, simplified operator interface is user friendly along with improved machine cutting motion so parts take much less time to make with better results.
Centroid Acorn CNC controller based Closed Loop AC servos or Open Loop Stepper kits available.
Call Gary Campbell (906) 250-4950 (c)
for more info or to order yours today!
103 Elm Street
P.O. Box 81
Bergland, MI 49910
Feature Highlights include:
‐ Fan cooled 20w x 24h x 8d powder coated gasketed steel control box
‐ Safety interlock loadbreak door switch
‐ Gasketed wire entry with retainer, cable glands
‐ Laser cut backplanes with tapped component mounting holes
‐ Lenovo CNC_PC, setup, tested with Centroid Pro license
‐ Mount bracket, breaker & wiring for one Teknic IPC5 power supply
‐ Centroid Acorn 4 axis Control board, 3 axis (XYZ) 4 motors
‐ Higher output (60 watt) DC power supplies (2 on ATC control)
‐ Spindle Speed & Logic (on/off)
‐ 24VDC Spindle Fan Terminals (with delay off control)
‐ Estop safety circuit cuts power to servos on activation
‐ Prewired Output relays (24V)
‐ C86 ACCP ClearPath connection interface board
‐ Circuit Breaker protection for all components
‐ Wire Ferrules on all connections
‐ All input, output and user connection terminals labeled
‐ All C86ACCP Teknic motor control connections labeled
‐ All Teknic servo power connections labeled
‐ Quality components throughout
‐ 1 year workmanship warranty
GCnC CNC Consultants and Trainers
Turn Key CNC Control boxes ready to install, Custom CNC Machines & Retrofit Mods
Link to GCNC AVID CNC Control box brochure.
Powered by the Centroid Acorn CNC Control Board and the C86ACCP Clearpath Connector Board
Testimonials
I have had a Shopbot since 2000 doing light commercial projects mostly prototype work. We had a plug problem with a x motor and it took out our control system. After working with Shopbot I looked into different control systems. We also do laser work and get much more control with that controller. That is how I found Gary and the Acorn system. I can not say enough about the easy installation and the control options the Acorn had. My wife works in the shop and was always afraid to run the Shopbot because you always had to pull in programs to do much, unlike the Acorn that provides buttons to most of the setup. Gary has been super for support and setup. Coming from the Shopbot control we did run into a few things that needed to be dial in the machine and Gray jumped right in and we got all up and working. If I were a hobbyist or light commercial like us I would not go to any other control then the Acorn because of the easy operations and options that you can use and the quality support from Gary. I understand that there is talk about a less expensive control but as a hobbyist you want to turn out high quality work in a reasonable time then I would stay with the Acorn. If I had to do it over today I would buy the Acorn control from Gary in a heartbeat. The support from Gary is worth the gold. - Chuck B.
I was primarily motivated to make this upgrade because I was not able to resolve software glitches and communication errors with the ShopBot control system. I was more or less satisfied with the performance of the ShopBot system when it was working. But - wow what a difference in controllers! With smoothing turned on in CNC12, and set at defaults for a "precision router", this system is sweet and smooth. Did I say smooth? It is SMOOTH! It engraves text more smoothly than I have ever seen this machine run before. The Clearpath servos are probably part of the improvement too but I think the biggest difference may well be the Centroid control software. I have a lot to learn. G-code is new to me. But this upgrade feels solid. Thanks to Gary for his help with this project! - Gerad M.
