The CENTROID T400 retrofit is a clean installation. The CNC control ships from the factory assembled and ready to install on the machine. The CENTROID electrical cabinet (gray box in photo) replaces the Southwestern Industries box for a factory look and finish. With a CENTROID CNC retrofit, Installation time is kept to a minimum, all CNC control electronics and electricals are installed, wired and tested at the factory.
Overview of major features added with the new control: -Constant surface speed machining
-Programmable spindle speed
-Improved threading cycles
-USB 2.0 ports and Ethernet ports
-Modern fast, software upgradeable CNC computer
-Solid state hard drive
-15" color LCD display
- Runs on industry standard G&M codes
-Color part program graphics with time estimation
-INTERCON conversational programming (creates G codes)
-Tool Check, stop and restart. Tweak in feature.
-Full size qwerty keyboard for easy programming/operating
-CAD/CAM system compatibility
-Warranty Service and Support |
