Dual Electronic Handwheels provide manual lathe feel on a CENTROID equipped CNC lathe
Dual handwheels for Lathes (Part #10787)
Control two axes at the same time. With the new handwheels you can jog two axis simultaneously, great for tool and part position setups on an Lathe or even basic turning. Nice smooth natural machine tool action. This unit shown can be used for Retrofits or with new OEM machinery. It can be mounted as shown using the supplied liquid tight case or can be flush mounted into your existing enclosure.
Also includes Fast Jog Joy stick for Rapid positioning
Intuitive handwheels provide the operator with a fast and easy way to setup a job. Move an axis just like a manual lathe. Great for touching off part zero positions and setting up tool offsets these CENTROID handwheels have a natural feel and can be used in conjunction with the axis Jog buttons on the operators control panel. A center mounted Joy stick allows for easy fast jogging of both the X an Z axis in both directions. The CENTROID dual handwheels can be mounted anywhere on the lathe with the provided sealed mounting box or the flaceplate mounted wheels can be mounted flush into your existing cabinet. For both new and retrofit applications.
