USB port for use with any USB Storage device.
Quickly and easily load G code programs and DXF files into the control with a USB thumb drive. Downloading large G-code part programs generated from a CAD/CAM system is now fast and simple. The control automatically recognizes the USB thumb drive and a drive letter shows up on the load menu along with the built-in hard drive. You can even graph the G-code part programs directly from the USB thumb drive to identify the program you want before downloading into the control. USB 2.0 and 1.0 drive support is a standard feature.
Included Ethernet Lan connection provided for Networking to your desktop PC.
Either USB or Lan can be used to transfer, copy, backup, G code, CAD/CAM and Conversational files with the CENTROID CNC control. (Either method is faster, better and easier than RS 232 or DNC file transfer) Now your CNC control is compatible with all modern computers.
