Centroid "USB-BOB" Operator Control Panel Interface Kit
usb bob, usb-bob, usb robert The Centroid USB Operator Control Panel Interface Board (aka "USB-BOB") is a CNC machine tool operator control panel interface board that connects to the CNCPC via a USB port and is currently plug-and-play compatible compatible with Acorn, AcornSix, and Hickory when using CNC12 v5.19.
Centroid "USB-BOB" Operator Control Panel Interface Kit (part #15380)
Centroid "USB-BOB" kit (#15380) includes:
   1x Centroid USB Operator Control Panel board
   3x Feed Knob Assemblies with cables
   3x 10-pin Terminal Blocks
   4x 5-pin Terminal Blocks
   1x 6' Right-Angled USB to Micro USB Cable
   4x 6-32x1/2" Standoffs
   4x 6-32x3/8" Screws
   4x 6-32 Lock Washers
USB-BOB Operator Control Panel Interface
Add to Cart
Shipping calculated during checkout.
(Duties and taxes are customer's responsibility)
USB-BOB has been through a 4 month alpha tester program with excellent results.
USB BOB is compatible with CNC12 v5.19 BETA software (the official release version will be CNC12 v5.2)
Typical Beta to Official release software time table is approximately 6-8 weeks.
USB-BOB requires Centroid CNC12 v5.19+ Beta Software
More information about USB-BOB Beta Software here.
The Centroid USB Operator Control Panel Interface Board (aka "USB-BOB") is a CNC machine tool operator control panel interface board that connects to the CNCPC via a USB port. The Operator Control Panel Interface Board is intended to be an affordable, reliable, alternative to traditional methods of building CNC control operator control consoles/panels. The USB-BOB provides inputs for the most commonly used operator controls in a package that installs in quickly with minimal fuss saving on wiring/installation labor and CNC controller inputs. It features inputs for three standard rotary encoders with integrated push-button, three MPG hand-wheel encoders, 12 optically isolated switch inputs, and 12 open collector LED outputs. The USB-BOB can be used in conjunction with Centroid's popular Virtual Control Panel or without.
The USB-BOB is plug and play with preprogrammed button and knob functionality: Many common functions like Cycle Cancel, Tool Check, Feed Hold and Cycle Start along with Rapid Override, Spindle Speed Override and Feedrate Override are preprogrammed and user select-able with easy drag and drop installation.
In addition to these pre-programmed controls, all controls are user configurable through Centroid's CNC PLC language so user can customize both the button or knob functionality to suit their application and tastes.
Common uses:
   • Physical buttons and knobs for core/common operator functions simplifying the design for a hard operator console
   • Supplement Centroid Virtual Control Panel with physical controls without using up any CNC control board inputs
   • Add separate Rapid Override to Centroid Legacy control systems that did not have this feature.
Centroid "USB-BOB" Operator Control Panel Interface Manual
USB-BOB Wizard Page, for easy setup and configuration!
USB BOB Wizard
USB-BOB Mill Video
USB-BOB Lathe Video
