Oak, Allin1DC and MPU11 CNC Software Levels
Features CNC12 Free v5.0+ CNC12 Pro v5.0+ CNC12 Ultimate v5.0+
Mill and Lathe Intercon Conversational programming Limited to 20 blocks of conversational Unlimited Unlimited
Wireless MPG Pendant support *** Not included Included Included
G-code program size Limited to 50Kb Mill , 5Kb Lathe G-code file size Unlimited G-code file size Unlimited G-code file size
Work Coordinates Systems (WCS) One (G54) Eighteen (G54-G59 plus extended WCS) Eighteen (G54-G59 plus extended WCS)
Menu driven Probing cycles Center of bore Complete Set of menu driven probing cycles. Bore, Boss, Slot, Web, Inside Corner, Outside corner, Single edge find, find angle, auto probe for CSR Complete Set of menu driven probing cycles. Bore, Boss, Slot, Web, Inside Corner, Outside corner, Single edge find, find angle, auto probe for CSR
Menu driven Digitizing cycles Grid, Radial, Contour, Wall following, limited to 2500 points Grid, Radial, Contour, Wall following, limited to 2500 points Unlimited point Grid, Radial, Contour, Wall following
Auto Tool Height Measurement Unlimited auto measure on:
Reference Too l & Tools 1,2,3
Unlimited auto measure on all tools.
Coordinate System Rotation Yes Yes Yes
Auto find CSR with Probe No Yes Yes
Manual find CSR with Probe or Wiggler Yes Yes Yes
Manual enter angle for CSR Yes Yes Yes
Tool Library 10 Tools 200 Tools, (99 Tools Lathe) 200 Tools Mill, (99 Tools Lathe)
Sub Programs and Macros (M98 & G65)
Write your own custom macros, many uses
Not Included Included Included
Cutter Compensation Included Included Included
Backlash Compensation Included Included Included
Screw compensation (laser or manual!) Included Included Included
3 axis simultaneous Included Included Included
4 axis simultaneous Not included Included Included
4th Axis linear or rotary conversational programming limited to 20 blocks of Intercon Unlimited Unlimited
Operate as a 2 axis CNC with Manual Quill Included Included Included
Operate as a 2 or 1 axis CNC control Included Included Included
Any axis can be Linear or Rotary Included Included Included
Spindle Encoder feedback,w/ RPM display Included Included Included
Mill Rigid Tapping Not Included Included Included
Lathe Threading Not included Included Included
Lathe Automatic CSS Not Included Included Included
Lathe Rigid Tapping Not included Included Included
Lathe C axis Not Included Not included Included
Lathe Automatic Tool Measurement Unlimited auto measure on:
Tools 1,2,3
Unlimited auto measure on all tools. Unlimited auto measure on all tools.
G81 drilling cycles Included Included Included
Compression Tapping Gcode Cycles Included Included Included
Mill G-code scaling and mirroring Included Included Included
True G-code backplot graphics Included Included Included
Run Time Program Graphics Included Included Included
Smart Search (stop and restart at any point) Included Included Included
User Configurable Touch Screen Virtual Control Panel ** Included Included Included
Backlash compensation Included Included Included
Menu driven Part and Tool setup menus Included Included Included
Intercon Teach Mode Limited to 20 blocks of Intercon Unlimited Unlimited
Intercon Drilling cycles: Drilling, Deep Hole, Chip Breaking Limited to 20 blocks of Intercon Unlimited Unlimited
Intercon Pocketing: Circular,Rectangular, Irregular Limited to 20 blocks of Intercon Unlimited Unlimited
Intercon Contouring Limited to 20 blocks of Intercon Unlimited Unlimited
Intercon Threadmilling Limited to 20 blocks of Intercon Unlimited Unlimited
Intercon Conversational Compression Tapping Limited to 20 blocks of Intercon Unlimited Unlimited
Intercon Auto Connect Radius Limited to 20 blocks of Intercon Unlimited Unlimited
Intercon Lathe Cycles. Auto profile cleanout, grooving, cutoff, chamfer, turning, end face turning Limited to 20 blocks of Intercon Unlimited Unlimited
Intercon Math/Geometry Help Limited to 20 blocks of Intercon Unlimited Unlimited
Operate in Millimeter or Inches Yes Yes Yes
4th axis Jogging Yes Yes Yes
Software Axis pairing. Pair an axes with the 4th or 5th axis. Allows Two axis to be paired axes. No Yes Yes
Auto Squaring of Software Paired axis with auto homing No Yes Yes
Hardware Axis Pairing Yes Yes Yes
4th axis G-code moves:
4&1,4&2,4&3,4&1&2,4&2&3,4&1&3&4, 4&1&2&3
No, "Free" is limited to 3 axis simultaneous .
Yes, 4 axis simultaneous movement
with full interpolation
with full interpolation.
Scale Input for axis positioning feedback No No Included
M0 Jogging No Included Included
PLC Detective Software Included Included Included
Use one input for all axis Homing Included Included Included
ATC support plugin No Requires ATC Software Plug-in Requires ATC Software Plug-in
Five axis or more fully interpolated simultaneous G code moves Requires purchase of Ultimate Plus Requires purchase of Ultimate Plus Requires purchase of Ultimate Plus
Offline Intercon Conversational programming software, Mill and Lathe (10730)
CNC Conversational Programming Software
Intercon is Centroid's conversational part programming system. Intercon is standard on all Centroid CNC controls. "Offline Intercon" is a second copy of Intercon to run on any Windows 7, 8 or 10 PC away from the machine.
This allows the operator to program parts in comfort of their office or at home. The Intercon USB Key allows you to install on as many PC's as you like.
more info on Intercon here...
Add to Cart
CNC12 Standard Included Oak and Allin1DC Hardware and Software Features
  • Built in Motion Control CPU
  • Mill and Lathe CNC software
  • Touch screen operators control panel (user configurable)
  • Reliable Ethernet communication with CNCPC
  • Runs on Windows 7, 8 or 10
  • Compatible with CAD/CAM systems
  • Runs Standard G & M Codes (see list in operator manuals)
  • 4 Mb G code program size (unlimited optional)
  • True G-code back plot graphics w cutter comp moves
  • 2000 line accell decell look ahead
  • Feed rate override operator variable 0-200% at 1% increments
  • Plug and Play dedicated MPG port
  • Rapid rate override
  • Spindle Control. on/off cw/cw, speed w/override
  • 12 bit analog output 0-10 VDC for VFD control
  • 16 optically isolated inputs, user configurable
  • 9 fused relay outputs, user configurable
  • Centroid Operator control pendant compatible
  • Six Encoder Inputs
  • Single 24 vdc logic power input
  • Spindle Encoder RPM display
  • Simple Menu Driven Operator Interface
  • Stop and Restart Job at any point
  • Tool Check, Jog and Restart at any point
  • Cutter Compensation
  • Conductive touch probe compatible
  • Kinematic touch probe compatible
  • Dedicated Touch Probe port
  • Coordinate System Rotation
  • 6 WCS G54 - G59 (12 more optional)
  • 4th axis software (both G code and Conversational)
  • Lube Pump control (user configurable to match pump type)
  • MDI mode with recent command memory
  • Programmable Auxiliary Function keys
  • Multiple Language Support
  • Stock PLC programs
  • User editable PLC programming
  • Part counter, Time, Time estimation
  • Simple Future Software updates available
  • G code editor
  • Utility Menu
  • Backup and Restore CNC config
  • Message Display and Logs
  • True Closed Loop CNC operation
  • Unlimited Program Storage (only limited by hard drive size)
  • Large easy to read DRO display
  • Menu Driven Part setup
  • Menu Driven Tool setup
  • Menu driven machine configuration setup
  • Fill in the blank Setup Menus
  • Run Menu
  • CNC control configuration menu
  • Restart Job Automatically
  • Any axis can be linear or rotary axis
  • G-code smoothing (user adjustable)
  • Auto Home to switch, user selectable direction per axis
  • Jog to Home or Home to Marks
  • Software Travel Limits (+ and - directions)
  • User configurable Slow, Fast, Max rates
  • User configurable axis motor acceleration
  • Backlash compensation
  • Gcode backplot checks work envelope
  • G code backplot shows true cutter comp moves
  • Vary part backplot speed and pause
    w/ G-code line display
  • Real Time Part Graphics, shows tool position while running
  • Optional Stops
  • Subprograms and Macros
  • Engraving compatible (short vector g code no problem)
  • Threadmilling (Mill)
  • Run in Inch or MM mode
  • Tool Library
  • Long part names
  • Drilling and Tapping Cycles
  • USB and Network Drive Compatible
  • Keyboard Operator Control panel emulator,
  • Xkeys USB control pad compatible
  • Tool Life Management
  • Ballscrew mapping table
  • Control relays and contactors thru Manual or Program control
  • User configurable custom DIY M-codes
  • Canned Cycles
  • Constant surface speed (lathe)
  • Threading (lathe)
  • Profiling with auto cleanout (lathe)
  • Lathe canned cycles (thread, groove, chamfer, cutoff,turning diameter and end face,
  • Scale input for DRO positional display of a manual axis
  • X/Y axis Deskew
