CENTROID KP-3 CNC Touch probe: Part, Vise and Fixture Probing: Automatically Set Zero points fast and accurate
KP-3 CNC Touch Probe
The CENTROID KP-3 CNC Touch probe is designed for Probing (part setup, zero location setup, and CMM type location and measurement of part geometry), component/fixture/work piece setup, inspection and 3D or 2D digitizing/surfacing. The KP-3 CNC Touch probe is made in USA with patented technology. Centroid has developed the KP-3 from its 30 years of probe building knowledge to achieve this affordable, accurate, robust design. Commonly used on Milling Machines, Machining centers, Routers and Turning centers. The KP-3 is a state of the art Kinematic touch probe and is compatible with most any CNC control that has an input for Probes. Acorn to KP-3 connection is a simple 4 wire hookup just follow the schematic. CNC software configuration is simple one button press with the pre configured preset for the KP-3 using the Acorn Setup Wizard. Also compatible with Mach3/4, WinCNC, LinuxCNC, Pathpilot and others.
KP-3 Acorn kit part# 14946
Probe Stylus Size and Price sheet
We stock common sized probe styl compatible with the KP-3
click here to download the Probe Tip Size and Price sheet. and Add to cart below.
CNC Touch Probe KP-3
- KP-3 probe
- 2.5 mm x 40mm carbide stem, ruby tipped stylus
- Stylus wrench
- KP-3 to Acorn cable
- KP-3 Users Manual
- KP-3 to Acorn schematic
CNC Touch Probe for Oak and Alllin1DC
KP-3 Oak/Allin1DC kit part# 14944
- KP-3 probe
- Stylus wrench
- KP-3 to to bulkhead cable
- Bulkhead to Oak/Allin1DC cable
- KP-3 Users Manual
KP-3 Specifications
Acorn KP-3 kit unboxing video
KP-3 Touch Probe Configuation & Testing
Surface Mapping with Centroid Acorn
Probe Styli Price sheet
We stock common sized probe styli. The KP-3, DP-4 and the DP-7 use the same styli thread mount, so these styli will fit all three probes.
Click here to download the Probe Tip Size and Price sheet.
cnc touch probe styli
