DIY gear we use but don't sell
We are providing these affiliate links below as a convenience as we and our power users have been using these DIY CNC accessories with good results. Note: No Warranty expressed or implied.
cnc pc beelink
A nice i5 PC for a CNCPC and a great deal and a cheaper i3 version!
Both have dual RJ45 (ethernet), desktop CPU, and good cooling.
closed loop stepper motor and drive
Stepper Motor Drive 48 volt DC power supply, Top Tip: buy TWO if you have a Router and dedicate gantry motors to one power supply.
Cat6a shielded ethernet cable
Cat6a Shielded Ethernet cable for CNCPC to CNC controller communication connection. 1ft, 3ft, 5, ft, 7 ft, 10ft, 14ft, 20 ft, 25 ft all the way up to 100ft. selection
Cat6a Shielded EtherCAT cable for EtherCAT Daisy Chain communication connection. 1ft, 3ft, 5, ft, 7 ft, 10ft, 14ft, 20 ft, 25 ft all the way up to 100ft. selection
See Kai's "CNC on the cheap" complete list here. https://centroidcncforum.com/viewtopic.php?f=60&t=8354
Ergonomic Super 4 Plus Automatic Wire Stripper for Wires from 0.2mm-6mm
Precision Mini Wire Stripper, 26-36 AWG for encoder wire
Standard but good quality Klein Wire strippers 20-30 AWG
Locktite Sleeving compound 620
Locktite "Sleeving" Bearing Mount
for Axis Pulleys and other CNC uses.
Can't build a machine without this stuff! Use on axis drive pulleys at the motor shaft and the ballscrew/rack end. Put a dab on the inside of the pulley and install it. This stops the pulley from working loose over time (set screws and flats can't take long term CNC use..they work themselves loose, this stops that!) Its always best to have a keyway that is fitted perfectly but 620 really does the job. Also used in sleeving shafts to increase their diameter , adapters, bearing setting etc.
- Budget push button box and estop, cycle start, cycle cancel, tool check, feed hold, etc.
- Cabinet building magnifying headband glasses
Be sure to see Kai's "CNC on the cheap" complete list here. http's://centroidcncforum.com/viewtopic.php?f=60&t=8354
As an Amazon Associate we earn from qualifying purchases.
