User Friendly DIY CNC Controls for Milling Machines,
Lathes,
Routers, Plasma
and other special applications.
Do-It-Yourself professional grade CNC control kits.
Acorn CNC control kits are both a CNC Hardware and CNC Software DIY system designed to work together for easy CNC setup and operation with minimal fuss.
Centroid "Acorn" Step and Direction CNC Controller kit: a
4 axis CNC control with built-in motion control CPU.
A reliable, high performance, industrial quality CNC control at a do-it-yourself price. Acorn utilizes an integrated 1Ghz ARM Cortex A8 Motion Control CPU and communicates with CNCPC via a fast and reliable Ethernet connection.
The Acorn CNC control board controls a wide variety of axis motors and drives
with industry standard step and direction command signal. Perfect for many types of machine tools such as: CNC milling machines, a wide variety of CNC Routers, CNC lathes to CNC Lasers, and other specialty applications. Compatible with small to large axis motors of all types and can be used with most any AC brushless servo motor drive packages such as: DMM, Delta, Estun, Teco, Teknic, Yaskawa and others. Any drive that accepts step and direction commands. Most all stepper motor drives are compatible with the Acorn board such as the popular Gecko and Leadshine stepper drives. Acorn runs on Centroid's proven industrial quality CNC control software.
The Acorn CNC system has been engineered, built, and tested at our Centroid facility in the USA. All units ship ready to run after thorough testing and quality control.
Email and Phone orders are also accepted. email diysales@centroidcnc.com or call 814-353-9256 ext 122 M-F 9-5 EST to place your orders.
Centroid Acorn CNC controller kit (part # 14455) includes:
- Acorn CNC control board
- Acorn Plug and Play Relay Relay Module
- Dual power 5 VDC and 24 VDC logic power supply
(50/60 Hz 100-120 VAC and 208-240 VAC input power)
- Logic power supply hookup leads
- 110 VAC power cord
- 15’ Shielded Ethernet cable
- Centroid CNC12 "Free" CNC Mill and Lathe software download - Touch Screen Responsive Operator Controls
- DIY self service CNC support thru Centroid Community CNC Forum which is Centroid Technician monitored and maintained.
- Optional Factory Direct Technical Support: $120/hr.
(Note: A 1920x1080 wide screen LCD Display is required and a Touch Screen is recommended.)
- $15 flat rate USA ground Shipping. most international orders add $30- $70
Bonus! Acorn Relay Module included with all Acorn CNC controller kit orders
Plug and Play Relay Outputs with the Acorn CNC Relay Board! Direct connection to the Acorn board with the supplied ribbon cable makes connecting and getting a relay board up and running a 5 second operation. The Plug and Play relay module allows CNC controlled connections to various CNC devices such as VFD’s, solenoids, lights, fans, pumps, motors, other larger relays and contactors in a compact format. The 8 relay module contains eight SPDT (Single Pole Double Throw) high current relays (10 AMPS at 250 VAC,and 10 amps at 30 VDC) which can directly control any device rated at or below the maximum rating of the relays. If higher current devices are required these relays can then in turn control larger relays or contactors to control the higher current device! Relay module has on board LED indicator lights for each relay.
Upgrade to Centroid Acorn Mill "Pro" CNC12 from the Free version that is included with each Acorn kit.
- Unlimited G-code file size
- 4th axis motor pairing with any other axis
- 4th axis G-code moves
Full version of Intercon conversational programming
- 4th axis conversational programming
Rigid Tapping
- Six WCS locations (G54 thru 59)
- Tool Library with 200 tools
- Unlimited Auto Tool Measure
- Full set of menu driven Probing cycles (Bore, Single Edge, Web, Slot, Inside corner, outside corner)
- BCD Tool Changer Output
- WMPG-6 support
- All features of the CNC12 Free are included
After purchase, the License will be sent via E-mail delivery. M-F 8-5 EST USA
Each Acorn Software License is specific to a single Acorn board.
If you are purchasing a license for a previously ordered Acorn kit please email a report.zip file to diysales@centroidcnc.com to expedite delivery.
Acorn Ultimate (Digitizing) CNC software license $399 (#14458),
or $299 Upgrade from Pro Mill or Router Pro
Full feature set of Digitizing and Probing capabilities for your Mill or Router
- 2D and 3D Digitizing, Grid, Radial, Contour.
Digitizing cycles is easy push button menu driven operation. (no macros needed!)
- Export Data to Cad/Cam
- Auto G code generation
- Unlimited Auto Tool Height Measurement
- Eighteen WCS locations (G54 thru 59 plus 12 more)
- Menu driven Auto Coordinate System Rotation with Probe
- Works with Centroid KP-3 Touch Probe or any other contact probe.
- All features of the CNC12 Free and Pro are included
- All future features added to Ultimate
Upgrade to Centroid Acorn Lathe "Pro" CNC12 from the Free version that is included with each Acorn kit.
- Threading (requires spindle encoder)
- Rigid Tapping (requires spindle encoder)
- Feed per revolution (requires spindle encoder)
- Constant Surface Speed
- 99 Tools
- Full version of Centroid Lathe Intercon Conversational Programming software:. Auto profile cleanout, grooving, cutoff, chamfer, turning, end face turning, threading and more.
- Unlimited G code file size
- WMPG-4 or WMPG-6 support
Acorn Router Pro CNC software license (for use with CNC12 v4.64+)
All the CNC features of Mill Pro but with a Router specific Virtual Operator Control Panel and the corresponding Router specific macros.
Acorn CNC control kit un boxing video.
Acorn CNC controller shop tour with MechtecMike
Video of Acorn CNC Single point threading, rigid tapping, profiling, encoder feedback, conversational programming on our in-house CNC Lathe test mule.
Vary part backplot speed and pause
w/ G-code line display
Real Time Part Graphics, shows tool position while running
Optional Stops
User editable Subprograms and Macros
Engraving compatible (short vector g code no problem)
Threadmilling (Mill)
Run in Inch or MM mode
Laser cutting and engraving support
PWM output control for Laser and/or Spindle
Tool Library
Long part names
Drilling and Tapping Cycles
USB and Network Drive Compatible
Distance to go DRO
Machine Coordinates DRO
Active G codes display
Software or Hardware paired axes
Auto Squaring of paired axis Gantry
Tool Life Management
Reset Home
Control relays and contactors thru Manual or Program control
User configurable custom DIY M-codes
Canned Cycles
Profiling with auto cleanout (lathe)
X/Y axis Deskew, corrects for axes out of square.
Mouse and Keyboard jogging in addition to VCP, MPG Pendant and Xkeys pendant, Contour Shuttle
Runs on 100-120 VAC OR 200-240 VAC power input.
Runs on USA and International Power
Use your own PC OR purchase a Centroid CNCPC
All-in-one Touch Screen CNCPC $1350
- Preloaded with Windows 10 and pre-configured for CNC PC duty
- Preloaded Centroid CNC software with G code Editor,
Intercon, Stock PLC programs, Acorn Install Wizard, Touch Screen
Operator Control panel.
- Touch Screen
- Wifi, Ethernet, webcam with mic, card reader, usb ports
- Powercord, Keyboard, Mouse
- Centroid tested and pre qualified to work with Centroid CNC controllers
- Compatible with Acorn, Oak, and Allin1DC - Model, Specifications and COLOR may vary.
Note: There are NO VESA mounting holes on this unit.
Planning to build or use your own PC as a CNCPC? Be sure the PC meets the Centroid CNCPC minimum requirements found here. The Centroid CNC software runs on any Windows 10 PC that meets the requirements.
- If you plan to build your own CNCPC follow the recommendations here.
- If you plan to buy your own PC we recommend the Intel NUC (be sure to purchase a NUC that meets the Centroid minimum pc requirements) and a 1920x1080 16:9 aspect Touch Screen monitor
- Centroid also offers for purchase CNCPC's with preloaded and pre configured software
Centroid NUC CNCPC $1050
- Allows use of any size and type LCD Touch screen. (1920x1080 recommended) or regular LCD monitor.
Preloaded with a licensed copy of Windows 10 and Windows is pre-configured for CNC PC duty
- Preloaded Centroid CNC12 software Mill and Lathe, Free version
- Pre configured Notepad ++ G code Editor
- Intercon Conversational
- Centroid CNC setup Wizard
- Touch Screen Operator Control compatible
- Intel processor and SSD (solid state drive)
Display port, HDMI, Ethernet, USB - Centroid tested and pre qualified to work with all Centroid CNC controllers
Ether1616 i/o expansion kit for the Acorn CNC controller (#14850) $329
The Ether1616 is an input and output expansion board designed to be used with the Acorn CNC controller. Each Ether1616 board adds an additional 16 optically isolated inputs and 16 relay isolated outputs to the Acorn CNC system, up to three Ether1616 boards can be added to an Acorn system for a total of 56 inputs and 56 outputs. Three different input voltages can be used: 5 volts, 12 volts and 24 volt. Input voltages are mix and match capable and are selectable via bank of four of inputs at a time with the provided plug-in SIP (Single In-line Pack) resistors. The default input voltage is 24 VDC.
Both the Ether1616 and Relay 8 modules provide both Din Rail mounting holes and Standoff mounting holes to allow the DIY installer a wide variety of mounting possibilities,
The provided dedicated power supply is sized properly to provide enough power to drive the 16 relays.
There are indicator LED’s on Ether1616 Inputs and on the Relay 8 Modules that indicate the state of the Inputs and Outputs.
The Ether1616 as the name implies communicates with the Centroid CNC12 software via Ethernet connection to the CNC PC. Ether1616 documentation is here.
Kit includes:
1.) Ether1616 Board
2.) Qty 2 Relay 8 Modules
3.) Qty 2 Keyed Ribbon Cables
4.) 24 volt DC power supply
5.) Ethernet Switch
6.) Qty. 2 Shielded Ethernet cables
7.) Qty 4 220 Ohm SIP resistors for 5 volt input
8.) Qty. 4 1k Ohm SIP resistors for 12 volt input
Estop Button with 2 contact closures $45 #14534
- Industrial quality reliable Emergency Stop Button with two switches.
- Two contact closures for two estop circuits
- Use just one contact closure or use both
- For use with the Acorn CNC control board.
International shipping is calculated after purchase.
Take the control to where the work is! A game changing tool, the Centroid Wireless MPG handwheel CNC Control pendant allows the operator to conveniently and precisely set up jobs and tools remotely.
No software or drivers to install. Plug and Play with Centroid CNC12 Pro CNC software, just plug in the included USB transmitter/receiver and start using it! Perfect for all types of Mills, Lathes, Routers and other specialty CNC machines. click here for more info.
KP-3 CNC touch probe
KP-3 kit for use with Acorn (part #14946) $699
Part, Vise and Fixture Probing: Automatically Set Zero points fast and accurate.
Use the KP-3 probe to quickly and accurately find zero points on a vise, fixture or part. Eliminate operator error when setting zero points, finding edges, or center locations of bosses or bores, slots and webs. Eliminates the need for a centerfinder or an edgefinder. You'll never have to spend 30 minutes using a center finder to locate the center of a bore again. The probe will find and set the center of a bore in just seconds. In addition the probe can be used to verify part dimensions and locations and many other applications. The KP-3 mounts in any 1/2" tool holder and has concentric adjustment screws. Patented and Made in USA. click here for more info and video on the KP-3
TT-4 CNC Tool Touch Off $660.Kinematic Design works with both conductive and non conductive tools and spindles.
Mill, Lathe or Router use. Quickly and accurately setup tool heights in the tool library with a push of a button. The CENTROID TT-4 automatic tool height offset touch probe is plug and play with all Centroid CNC controls. Eliminates gauge blocks, paper, and repeated measurements. Save time and increase accuracy. Fully integrated into the CNC control tool library menu, just select the tool and press auto measure to set the tool height automatically. Makes measuring all types of tools faster and more accurate. Find the longest insert in a multiple insert tool quickly. Once you start using the TT-4 you'll wonder why you waited to purchase this time saving tool. Measure just one tool or a whole group of tools at once. Can also be used in the middle of a job to measure a replacement tool. Integrated with an Automatic tool changer for batch tool measurement. The TT-4 is based on KP-3 touch probe technology and is a robust kinematic design and works with all spindles even ones that with non conductive bearings (ceramic) or tooling that doesn't conduct (diamond).
- Set Tool Lengths automatically
- Ultra accurate conductive design
- Save time, increase accuracy
- Magnetic base or hard mounts (T-nut or Shank)
- Works w/ CENTROID & most other CNC’s
- Easy to achieve high precision measurements
- Designed for milling and lathe applications: Kneemills, Bed mills, Machining centers and Routers,
Lathes and Turning centers
- In process tool reset for worn out or broken tools
- Requires conductive tools
- Serviceable unit
- Auto cable detection
Offline version of INTERCON Mill, Lathe and Plasma (in beta) conversational programming, for use with Windows desktop PC*, $159
- For those that do not want to use or learn a CAD/CAM system to make CNC parts.
Program parts in the comfort of your office.
- Program while the machine is running a job.
- Easy part program transfer from your PC to the control via LAN or USB.
- True G-code backplot graphics, see exactly what the machine toolpath will be.
- Use on the same PC as your CAD system.
- A USB Keylock allows user to install software on as many computers as they want.
- Offline programming USB keylock is shipped the next business day.
- Works with Windows 7/8/10/11*
- Manual with tutorial examples see Mill Chapter 10, Lathe Chapter 8
Purchase Centroid Factory Direct Technical Support. Professional experienced Centroid CNC control engineers will work with you to configure your CNC machine tool. Centroid Direct Technical Support is provided through Phone, E-mail, and preferred and most effective method is remote support via TeamViewer.
Centroid Acorn CNC controller reviews.
"Looking to order boards and other parts from you this week. I've got to admit - SO NICE having a board and software made by the same company. No plug ins from other places and the headaches. Literally followed the video and the motors were turning by the time it was done. -Revy
"After dealing with Mach 3 and LinuxCNC for years, I must say Centroid is Light years ahead. Up and running bench test in a matter of minutes instead of days as with those other products. There is much to learn about Centroid but I am confident it is a very solid product. I can't find the words to properly describe the difference." - Makeron.
"My son came to me and said that the students in his high school woodworking class could not finish their projects due to their CNC router is broken. Well I couldn't let this be and in less than an hour, I installed a acorn on their router and all the students were able to finish their projects. I donated the board to the school so they could continue to use the router and many students will be able to familiarize themselves and use the Centroid control. Thank you Centroid for making such an awesome easy to use and install product. Keep up the good work!" - Extreme industrial
cnc_jim wrote: ↑I have to say a big THANK YOU to Centroid for providing the best value in DIY CNC on the market today. I just completed the upgrade of my CNC router table to Acorn and couldn't be happier! Followed the schematics for the GeckoDrive 203V (only thing I kept from my old controller) and everything just worked without any issues. Watched a lot of video's that provided almost everything I needed to get my machine working. I saved so much money over upgrading to Mach4, Smooth Stepper and PMDX boards that I had planned for my initial upgrade that I bought a touch screen monitor, wireless pendant and upgraded to Mill Pro. The pendant is just amazing to use. I feel like I have a professions system now! Not sure how you can sell the entire acorn kit for the price you do, but thank you for providing this to the DIY community.
Yesterday, I received a model 4 Acorn and an extra relay board for my model 3 Acorn that I bought almost a year ago. Opening that package reminded me of the care and concern that Centroid has for its customers. The power supply was pre-wired for the Acorn. The instruction sheet is comprehensive. The backside of the instruction sheet that shows a connection schematic that should make initial connections fool-proof. I just noticed that even those schematics are printed in color. (My eyes have serious problems.) The new schematics that Keith notified us of have fixed all of the connection problems that I've experienced with ClearPath servos, Gecko G203 drives, and Leadshine (clone) drives. Those problems were not Centroid's fault. (The older schematics followed wiring diagrams from other manufacturers that were somewhat lacking. I've read Teknic's manual carefully about the fault signal. The older schematics followed the Teknic manual. Keith and Gary solved that problem months ago, but because I had a work-around, I didn't carefully read the revised schematic that Centroid published months ago.) I was able to work around those problems; but the new schematics make those work-arounds obsolete. It amazes me that Centroid is willing to spend money on so many do-it-yourself motors, drivers, spindles, VFDs and other non-Centroid products, test those products, draw up schematics to use those products and still sell the Acorn for $329 with the amazing Centroid software.
Next, the forum along with YouTube videos are great. Keith, Marty, Gary and Franco not only show how to use the Acorn, but teach general principles about CNC machining. Late last night when I couldn't sleep, I watched a video where Keith showed how to use a vertical mill. The video contained everything that anyone would need to see how to use Centroid products to make their equipment work. Clicking on "Acorn User Videos" from the Acorn page shows a list of videos that show how to use the Acorn. Going on YouTube and searching "Marty CNC" brings up Marty's channel with a comprehensive list of how-to videos. Searching "Gary Campbell CNC" brings up Gary's channel and his expertly produced videos. (Gary and I go back decades to my Shopbot days when I constantly used his advice to solve my problems.) Clicking on "Centroid CNCKeith" brings up Keith's videos. His knowledge and easy-going style should make anyone comfortable in trying an Acorn. One of his videos was with "MecTechMike". Mike's mill and lathe conversions should impress everyone. He surely impressed me and gave me ideas that will take at least a year to try. There are many, many others who have taken the time to post videos showing how they use the Acorn and other Centroid products.
The forum is invaluable. Questions are answered expertly (in most cases). Since I tend to be disruptive in some of my posts (unintentionally - I like to think outside the box and try things that might seem to be controversial), I expected harsh feedback or even censoring, but I've been treated with respect and courtesy. More, importantly, by reading what others are doing, I get ideas that would take a life-time to implement.
Thanks Centroid and thanks to all of you in the Acorn community for your help.M Richards
All prices and specifications are subject to change without notice
