Choose from standard CNC control configurations or fully customized to meet the special machine tool applications
Industrial Grade High Performance CNC Hardware and Software backed by 38 years experience. |
Not a Kit! this CNC system is Bolt-on ready, we did the wiring work for you. All CNC components are wired, tested and ready to run.
Hookup cables are labeled for easy connections to Flood Pump, Lube Pump, VFD (spindle inverter), Mister, and Limit Switches and Servo motors. |
Made in USA DC Servo based M400S 3 axis Pre-wired ready to run. $11,935
IN STOCK! Ready to Ship, use order #StockS, click for pdf quote
AC servo based Small Milling Machine CNC Control system: $16,980
M400 3 axis with 1Kw AC Brushless Yaskawa servo motors and drives
AC servo based Medium Milling Machine AC CNC control system: $19,116
M400 3 axis with 2Kw AC Brushless Yaskawa servo motors and drives
AC servo based Large Milling Machine CNC Control system: $24,488
M400 3 axis with 4.4Kw AC Brushless Yaskawa servo motors and drives |
1.) Call us to speak with a Sales Engineer at 814-353-9218 (M-F 8:30-5 EST)
2.) Email our Sales Engineers at diysales@centroidcnc.com
3.) Online Contact Form (View Contact Form) |
Made in USA DC Servo based M400S 2 axis Pre-wired ready to run
Perfect for
Flat Bed Lathes and Small Slant Bed Lathes: T400S $11,835, click for pdf quote
AC servo based for Small Slant Bed Lathes CNC control system: $15,273
T400 2 axis with 1Kw AC Brushless Yaskawa servo motors and drives
AC servo based for Medium Slant Bed Lathe CNC control system: $16,795
T400 2 axis with 2.2Kw, 2.2kw w/brake AC Brushless Yaskawa servo motors and drives
AC servo based Large Slant Bed or VTL CNC control system: $20,802
T400 2 axis with 4.4Kw, 4.4 Kw w brake AC Brushless Yaskawa servo motors and drives
