Specialty CNC Machine Tools |
HO manufactures a series
of compact CNC mills. 3 and 4 axis machines with and without tool changers are
available. The MHO compact mills are a high performance CNC mills designed for
precise machining of Electrodes , Engraving dies, Jewelry patterns and more. click here for more information. |
CENTROID's unique C axis drive mechanism provides true SERVO motor C axis spindle drive. The servo motor driven spindle C axis provides superior machining performance while holding tight tolerances. Not to be confused with inferior inverter driven schemes! The CENTROID C axis mechanism is a zero backlash design and is gearless. This long life high performance design ensures years of reliable C axis operation. click here for more info.. |
CENTROID has developed a new high performance affordable 5 axis machining center. Its Bostomatic like action has been improved upon with its unique ballscrew drive which results in fast, smooth, accurate and reliable 5 axis machining. click here for more info |
The CENTROID CNC control is suited for retrofit on a wide variety of machines tools. Its advanced CNC CPU and PLC is perfect for upgrading older NC/CNC machines tools to elminate repair costs and bring the machine tool back to life. CENTROID has specialized in complex CNC retrofits for 30 years (as well as simple knee mill and router retrofits). Our retrofit knowledge and experniece ensures a sucsessful integration which results in a productive money making machine tool. click here for a slide show. |
4 axis CNC Welder Precision CNC welding
price breakthrough! Tig or Mig weld almost anything with this new
CNC welding machine. Accurate, repeatable results yield a superior
weld with less scrap than welding by hand. This machine handles
both thick and critical thin wall welding with ease for superior
penetration and weld strength.
Click
here for more info.... |
2 axis CNC Diamond wire machine Used for making Carbon EDM electrodes
for Extrusion Die production. Not an EDM machine, This machine actually
makes the plunge EDM electrodes to produce sophisticated extrusion
dies. This machine uses a fine diamond wire to cut hard materials.
Now you can bring in house that electrode work for faster turn around
times with less expense.
Click here for more info. |
Automatically Duplicate hand shaped combustion
chambers, intake and exhaust ports. Both copy and cut with the same
machine. With this machine you can machine a new casting to an exact
shape as well as repair a damage combustion chamber. The CNC head
machine produces consistent shapes for the best quality cylinder
heads for racing and high performance engines. This new machine breaks
the price and performance barrier, no race or repair shop
should be without this machine.
Click here for more info.. |
