CENTROID
Hardinge CHNC/HNC Retrofit kits. |
This
kit is all you need to upgrade any Hardinge CHNC or HNC lathe. Our
kit is the easiest and fastest way to upgrade a Hardinge. We supply
you with everything you need. The system is completely prewired
and tested before it leaves the factory. All PLC programming has
been done for you. Our Kit replaces all existing electronic components
and includes a new spindle motor,encoder and inverter along with
new DC Servo axis motors** with encoders.
Our Hardinge
kit takes all the time consuming problems out of a retrofit, we
have done the work so you don't have to! Specialty Installation
hardware and drilling templates for specific CHNC/HNC machines are
included. A typical CHNC retrofit takes only 2 days with basic shop
tools.
Our retrofit
package makes the Hardinge perform better than new! Give your Hardinge
what it deserves, a CENTROID CNC.
CENTROID
CHNC Retrofit features:
Single
or Three Phase Operation.
One source
for all retrofit components.
Completely Assembled & Tested CNC system.
Adapters and Drill Templates included.
Fast, easy install.
Pictorial install manual on CD.
Better than new performance.
Fast tool changes.
Programmable spindle speed.
Automatic CNC Turret.
Moveable control stand with locking casters.
Hand Held CNC control pendant.
Constant Surface Speed with Threading
Reliable CENTROID amplifier and PLC
Uses Standard VGA monitor and PC Keyboard
Everything
You need comes in one Box!
New 5hp AC Spindle Motor with new belt and pulley.
New Spindle Encoder.
New spindle motor Inverter.
New Axis Motors** and Encoders.
Specialty Installation hardware included.
Control Stand with locking casters.
Hand Held CNC Control Pendant with dock.
System is completely prewired ready to install.
Preprogrammed PLC for all M Functions and CNC Turret.
Installs in 2 Days with basic shop tools.
State of the art CENTROID T-39 Dual processor Pentium PC Based CNC,
with DSP motion control.
Step by Step pictorial Installation Manual on CD.
The
original Servo motors can be reused if they are in good condition.
If you can reuse the stock motors, this saves a little on money and
time. Centroid does offers New replacement servo motors as well for
the cases where the original motors are damaged or missing.
**New
axis motors are supplied when the original motors are worn out or
missing. |
| Hardinge
HNC/CHNC retrofit upgrade control kits |
Price |
| 10509
T39S DC W/Remote Pendant, use original motors, no spindle
motor or inverter |
$10,311 |
| 10508
Add on: Two new DC 17 in-lb replacement servo motor |
$1,065 |
| 10812
Add on: New 5 Hp AC spindle motor and inverter kit w/adapt
hardware |
$please call for price |
| 10813
T-39S DC Complete Harding HNC/CHNC Retrofit Kit |
Click
here for your Free Hardinge CENTROID Retrofit DVD Video |
If
you are looking for information on Hardinge HLVH Retrofits..click
here... |
