The CENTROID
CNC control is loaded with high-end features |
FREE
USB port for use with any USB Storage device.
Quickly and easily load G code programs and DXF files into the control
with a USB thumb drive. Downloading large G-code part programs
generated from a CAD/CAM system is now fast and simple. The control
automatically recognizes the USB thumb drive and a drive letter
shows up on the load menu along with the built-in hard drive. You can even graph the G-code part programs directly
from the USB thumb drive to identify the program you want before
downloading into the control. USB 2.0 and 1.0 drive support is
a standard feature.
You can even use a floppy disk drive with this port. A standard
USB external Floppy Disk drive will plugs right in.
click on image for larger view. |
NEW AC Brushless servo drive and motor technology.
New CENTROID AC brushless servo drive technology is now available. The new servo
drives are powerful and fast. Fiber optic communication with autotuning. In addition
to the new AC drives, a new DC single is added to the line up. The DC single
designed for easy 4th axis add on or as a stand alone single axis drive. Click
here for more information on our new drives.
Click
on photo for larger view!
Large
color LCD display for easy setup
and programming
No
other control has such a large easy-to-read display. With a special
no-glare coating, the CENTROID LCD display is sealed from liquids
and greasy fingers. With the high res 15" display, Programming, Editing,
and viewing tool paths is now a joy.
- Large bright
letters.
- Color tool
path graphics shows cutter comp moves
- Easy to view
from any angle
- No flicker,
no ghosting, long life, runs cool
- Perfectly
flat for accurate graphics
- Sealed from
shop coolant and oils
- Special
no-glare coating
Click
Dedicated
CNC control panel is straight forward.
- Individual
dedicated buttons for all common machine functions
- One-button
operation to Jog an axis
- One-button
tool check
- Sealed from
- Long-lasting,
durable overlay.
- Tactile feedback
(button depresses with distinct feel)
- Easy to read,
well-labeled, intuitive layout.
Click
Color
Tool Path Graphics shows tool path
of cutter comp moves
- Make
fewer programming errors with our excellent tool path graphics.
- Instantly
see the tool path at any point while you are programming. Great
for checking your work as you go.
- Run-time
graphics show you the cutter position while the job is being machined.
Great for large machines and for when the cutter is buried in
flood coolant.
- Graph and
edit G code programs from any source right at the control.
- Graph Digitized
part programs
- All 2D views
and 3D, zoom in/out, slow down or speed up, pause graph, graph
any the whole part or just a section, different color of lines
for different types of moves.
- Very accurate
run-time estimation
- True backplot
graphics, WYSIWYG. What you see is what you get -- not just a
guess like other graphics!
USB, Ethernet LAN, RS-232, Floppy Drive
and MPG electronic handwheel connector.
CENTROID CNC controls feature
convenient connectors for USB micro drives, Ethernet Lan connections,
Traditional RS-232 serial port, PC compatible Floppy drive and MPG
electronic Handwheel connector.
Click
on the photo for a larger view with explanation of each connector. |
Click on image for larger view! |
FREE!
High Speed Processing for 3D machining
- 2000 line
lookahead accel/decel.
- High Block
throughput.
- Continuous
tool motion with no hesitation or dwell.
- Reduces bench
time grinding and polishing.
- Take lighter
cuts faster for better surface finish.
- Run programs
with very short moves at high feedrates.
- Stop
and restart at any point.
Intercon
Conversational Programming for Mills and Lathes
- Program
parts right at the control or offline* with your desktop
PC, fill in the blank programming.
- Centroid's
Intercon generates the G codes for you.
- Help screens
for all the common milling/turning cycles,
just fill in the dimensions. Even lines and arcs are canned cycles.
- A graph of
the part shows your work as you go. Graph at any point.
- Automatic
pocket cleanout, Intercon auto creates the
roughing and finish passes automatically.
- Fill in the
blank: Threadmilling, Drilling, (3 types of cycles), Tapping
(Rigid, Rigid peck tapping, Floating), Pocketing, Facing, Auto
connect radius, Lines, Arcs, Math Help, Teach in and much more!
- Convert
geometry from DXF files to Centroid's Intercon* operations.
Supports contouring, pocketing, framing, drilling, boring,
tapping, & threading.
Click for more info |
Make
threads with your milling machine with Threadmilling.
- A canned cycle
in CENTROID's Intercon conversational.
- Large diameters?
No problem.
- No Lathe
necessary.
- Make: Inside,
Outside, Right and Left hand threads
- Multipoint
and single point tooling supported
- Fill-in-the-blank
programming with graphics
- English
or Metric
- Multi pass
generation is automatic
- Machine
threads not possible with a tap.
