Now with Windows OS and solid state hard drive, touch screen as standard equipment
click on image for larger view |
• 4 axis with spindle control standard
• 5,6,7,8 axis simultaneous contouring optional
• DSP high block throughput & high-speed machining
with 2000 line accel/decel lookahead
• Digital servo drives, AC or DC servo motors
• Standard Solid State Drive (SSD)
• Easy-to-use part and tool setup menus
• 15” touch screen LCD display
• 3D tool path graphics with runtime display
• Runs on industry standard G & M codes
• Compatible with popular CAD/CAM systems
• Remote Access support via internet connection
• Windows OS, easy networking & file transfers
• Custom UI Screens for special applications
• Run 3rd party software of your choice
• Subprograms, WCS and Macros
• Laser ballscrew mapping
• One button push for common machine tool functions
• Axis pairing, Multiple spindles, Scale inputs
• Quickly create part programs right at the control
• Easy “fill in the blank” menus
• Graphical help menu with math assistance for
missing dimensions
• Software automatically generates the G-code
• Check work instantly with 3D tool path graphics, graph at any point
• No knowledge of G-codes necessary
• Drilling cycles: Deep hole, Chip breaking, Regular
• Drill BHC, Drill array, Drill repeat
• Lines: end points and polar
• Pockets: rectangular, circular and irregular with
auto-cleanout, island avoidance and finish passes
• Repeat whole parts, events, or a matrix of holes
• Mirror and rotate whole parts or one entity
• Threadmilling: inside, outside, left and right handed
• Arcs: EP & R, CP & A, CP & EP and 3-points
• Frames: inside and outside of rectangular, circular
• Teach mode
• Easy 4th axis programming
• 3D Print Additive canned cycles.. Click here for more part programming
info. |
• Install and operate most any CAD or CAD/CAM software
directly on the Centroid CNC control
• Allows operator to use a CAD or CAD/CAM program to
look up part dimensions, create and modify part programs
• Utilize CAD/CAM part machining simulation backplot and
verification features directly at the control.
• Open CAD files directly on control via USB or LAN
• Run most any other windows compatible software or
hardware: Skype, Teamviewer, G-code editors, Webcams,
Microphones, Speakers, Wireless devices, backup
Hard Drives, etc. |
• Carousel, Swingarm and Rack tool changers
• Control up to 200 tools
• Menu-driven tool changing w/o using G-code
• Random Access, Bidirectional
• Batch ATC Auto tool measure functionality
The
CENTROID CNC control can operate a wide variety and types of tool
changers. Umbrella type to Swing arm -- the Centroid provides fast
repeatable tool changes. Automatic batch measurement is also available
when used with our TT-1 Auto Tool Setter. Just highlight the tools
you would like to measure and the batch feature will automatically
retrieve, measure, and replace each tool automatically. |
• Duplicate parts in 2D or 3D
• Easy menu-driven fill-in-the-blank digitizing cycles
• Perform grid, radial, contour & wall following digitizing
• Automatically generates G-code and Cloud Point Data
• Export data to most any CAD/CAM system
for further editing and shape manipulation
• Autonomous cylinder head port & combustion digitizing
• Probe and Software designed to work together
• DP-4 all around .0001" accurate 3D touch probe
• DP-7 specialized long styli application touch probe
Copy and Cut 2D and 3D shapes. Centroid's affordable, effective Digitizing
is the simplest CNC Digitizing on the market. Just record and play
back. Do you have a 2D contour such as a CAM or a 3D part like a mold
or plug? But no print? Let our Digitizing feature copy the part for
you. Digitizing turns your milling machine into a copy machine. Centroid
has overcome the cumbersome problems associated with Digitizing on
other controls. With a Centroid, it's actually one of the simplest
features on the control to use. With our Digitizing feature you will
be able to copy and reproduce an existing shape with little or no
programming! No CAD/CAM necessary, however you can export the Digitizing
information to a CAD/CAM system for further modification. It's very
popular for repairing cylinder head combustion chamber damage, copying
cams, creating molds and plugs from existing objects and many other
uses.
Click here for more on Digitizing... |
• Effortlessly measure tool heights
• Repeatable results for consistent part production
• Faster and more accurate than manual methods.
• Significantly reduce setup time
• One-touch operation sets tool heights
within 0.0001” in seconds
• Menu-driven automatic tool measurement
• TT-1 conductive, TT-2 non-conductive probes
Setup
your tools in a quarter of the time it would normally take! If
you often machine short run parts and are always setting up and
tearing down for a new job, Auto Tool Set will save you
tons of time, while more accurately setting your tool height offsets.
With the TT-1 or Tt-2 you can create more parts per hour since the tool
set up is so much faster. You'll even save time when you have
to replace a dull tool with a new one in the middle of a job.
Auto Tool set is completely automatic. Press "measure" and
the tool will automatically touch off and set the tool
height offset in the tool library. . |
• Touch probe with Probing cycles offers accurate
part and fixture setup with the push of a button
• Automatically set Part Zero position,
quicker and more accurately than manual methods
• Finds edges, corners, bore centers, boss centers and
fixture offsets & angles in seconds
• Automatic Coordinate System Rotation*,
never manually tram a vise again
• Reset fixture locations automatically,
never use a center finder again
• Much faster and more accurate than indicating by hand
• DP-4 Kinematic seat: all around high performance probe
• Specialized DP-7: Solid State design for long styli
• Reliable Plug and Play CNC Probing
• Easy menu driven fill-in-the-blank probing cycles |
- Clearly labeled
controls for each axis and direction.
- Dedicated
buttons for spindle and coolant controls
- One button push for common machine tool functions
- Spindle speed
override and Feedrate override.
- Tool Check,
Feed Hold, Cycle Start, Rapid override,
Incremental and Continuous Jog, Single Block.
- Customize
with Tool index +/-, Clamp/Unclamp, Vac on/off, & more.
- Extra auxiliary
buttons are programmable for special applications.
- Fully sealed,
coolant proof, long-lasting in shop environment.
- Tactile feedback,
raised buttons with distinct action.
- Indicator
lights show the selection made.
- Stop and
restart the job at any point.
- Stop, make
any adjustments, and restart right where you left off.
- Analog Feedrate override for ultimate control
- Individual Rapid Override, Feedrate Override control or combined
- On-the-fly
override control of feedrate and spindle speed
- Tool Check allows easy program interruption and restart
- User selectable Incremental jogging
- Incremental or continous Jogging
- Fully sealed,
- Tactile feedback,
- User/Installer programable auxiliary keys can be used for any custom machine tool function , hundreds of custom labels are available.
Quickly and easily load G code
programs and DXF files into the control with a USB thumb drive.
Downloading large G-code part programs generated from a CAD/CAM
system is now fast and simple. The control automatically recognizes
the USB thumb drive and a drive letter shows up on the load
menu along with the built-in hard drive.
You can even graph the G-code part programs directly from the
USB thumb drive to identify the program you want before downloading
into the control! USB drive support is a standard feature.
Ethernet LAN connection, and MPG connector are also
standard features of the M400 CNC control.
hardware:Webcams,
Microphones, Speakers, Keyboards, Mice, backup
Hard Drives, Wireless devices etc.
• Allows use of solid tool holders with your tap
• Special deep hole tapping cycle for large diameters
and Threadmilling for diameters that are too large to tap |
Ready to run pre-wired closed loop CNC systems with AC or DC
Servo motors up to 8 axes, preconfigured I/O and pre-wired machine
tool accessory cables customized to any machine tool.
• Pre-engineered CNC control packages are available
for: knee mills, bed mills, machining centers,
boring mills, additive 3D printing, routers, and
many other machine tools
• Common CNC control configurations are in stock
and ready for immediate shipment
• Custom built to any machine tool specifications
• Retrofit upgrade kits for good machines with
obsolete controls
• Ready-to-run CNC systems for new machine tools
Not
just a box of parts! Centroid's ready to run CNC controls are the fastest and easiest
to integrate CNC onto a new machine. The controls arrive ready to install
with the control panels pre-configured for your particular machine,
saving hours -- if not days -- of installation time. PLC ladder logic
is also preprogrammed for your particular machine. The M-400 is available
with our affordable DC brush axis motors or AC Brushless servo motors |
• CENTROID designs and manufactures its own state-of-the-art CNC control components.
This allows us to provide the industry’s most affordable replacement CNC parts
and CNC support long after the sale.
• Low CENTROID CNC control operating costs increase your bottom line.
• CENTROID is a U.S. owned and operated company with thousands of CNC controls in
operation worldwide. |
True
simultaneous 5 axis CNC machining. |
CENTROID High speed
5-axis machining centers are now available. Bostomatic style with modern day improvements. Fast, Smooth, consistent 5-axis motion.
Great for medical, aerospace and any industry needing an affordable accurate made-in-usa 5-axis machining center that is easy to use.
Complete packages available with training. X,Y,Z,A and B motion all at the same time or in any combination.
5 axis control systems are available separately for milling machines and CNC routers for new or retrofit applications.
see a video of our 5 axis machining center in action...click here.. |
CENTROID
CNC Service and Support |
CENTROID
CNC controls have a proven reliable track record and offer cool, quiet
operation. Our controls are easy to maintain, with autotune, dragplot, self diagnostics and remote access support.. Centroid CNC users are supported by a world-wide
network of local Factory-Trained Technical Representatives who provide
fast affordable service, training and upgrades. Centroid users can
stay up with current technology with easy Centroid CNC software updates.
In just minutes new CNC features or accessories can be added to the control. |
