New
CNC products, New CNC technology... |
New! CENTROID Turn-key 5 Axis Cylinder
head machining center package.
CENTROID offers the most complete CNC porting system
on the market. Everything you need to start CNC porting cylinder
heads is offered, one stop shopping. Our complete package is by
far the fastest and best way to have your shop start CNC porting
cylinders heads.
Click here for more info... |
DX1 Single axis CNC controller for Rotary or Linear
applications.
CENTROID's new DX1 single axis CNC controller
is designed for use with any make CNC/NC machine tool
OR Manual machine. This versatile easy to program CNC control
can power AC (brushless) or DC (brush) servo motors. Our Rotary
Indexer packages offer affordable automation for your machining
center or knee mill. The DX1 is made in the USA and is based
on proven reliable user friendly CENTROID CNC technology.
click here... |
In
Stock Ready for immediate delivery!
We Stock the following common control systems for immediate purchase
and delivery. 0 lead time!
Two common types of M400 3 Axis systems are in stock:
Inverter systems and "M Function"
systems. The Inverter system is for use with a three axis milling
machine that uses a Frequency Inverter to control spinlde speed on/off
cw/ccw. The "M Function" system is for use on a milling machine that
uses contactors to turn the spindle motor on/off cw/ccw and not an
inverter. The M function system comes will all the contactors factory
installed and prewired for spindle control and coolant flodd and
mist.
CAD to CNC, DXF file import
with Intercon Conversational.
Convert DXF files into G code with CENTROID's
Intercon conversational programming software. NO CAD/CAM system necessary.
Fast and simple, this new feature allows you to create parts directly
from a CAD file on the control or on your desktop PC. You can even
combine any or all of your CAD file with any conversational events.
This is the most flexible way to take advantage of both CAD/CAM like
programming with the simplicity of conversational. This new feature
saves you both time and money, less expensive than a CAD/CAM system,
much easier to learn with faster results.
more
info here... |
