Centroid turn-key pre-wired ready-to-run CNC Control System prices starting at:
Small Milling Machine CNC Control system: $16,980
M400 3 axis with 1Kw AC Brushless Yaskawa servo motors and drives
Medium Milling Machine CNC control system: $19,116
M400 3 axis with 2Kw AC Brushless Yaskawa servo motors and drives
Large Milling Machine CNC Control system: $24,488
M400 3 axis with 4.4Kw AC Brushless Yaskawa servo motors
and drives
Small Slant Bed Lathe CNC control system: $15,273
T400 2 axis with 1Kw AC Brushless Yaskawa servo motors and drives
Medium Slant Bed Lathe CNC control system: $16,795
T400 2 axis with 2.2Kw, 2.2kw w/brake AC Brushless Yaskawa servo motors and drives
Large Slant Bed or VTL CNC control system: $20,802
T 400 2 axis with 4.4Kw, 4.4 Kw w/brake AC Brushless Yaskawa servo motors
and drives
DC Servo Motor based pre-wired electical ready-to-run CNC system prices start at:
Knee Mills, Bed Mills, Routers: M400S $11,935 IN STOCK! Ready to Ship, use order #StockS, click for pdf quote
Flat Bed Lathes, Small Slant Bed Lathes: T400S $11,835, click for pdf quote
Call or click here for a detailed CNC System quote for your particular machine tool.
CNC Component Level Pricing for Do-It-Yourself Installation, Shop DIY CNC kits starting at $325.
CENTROID Allin1DC CNC Controller based system overview and price sheet.
Use Allin1DC based systems for Machine tools with DC servo motors from 7 in-lb up to 40 in-lb
Typical applications are Knee mills, Bed Mills, Small and Medium sized Machining Centers, CNC Routers and Lathes
DC servo motor based CNC control system
click on image for larger view
Click here to download hi res PDF good for printing
CENTROID's made-in-USA "All-in-One-DC" control card is the pinnacle of CNC control technology. The culmination of 30 years of CNC control design, manufacturing and installation, CENTROID's CNC CPU, Servo Drive and PLC have come together in one amazing printed circuit card. The All-in-One-DC cnc control card combines CENTROID's renowned digital DC Servo motor drive with its powerful MPU11 CNC CPU (the 11th in a long reliable linage of CNC cpu cards) and its own CNC PLC (designed with functions geared towards machine tools). The All-in-One-DC provides reliable operation with simple installation. reducing cabling, connectors, space needed for install, power supplies while increasing noise immunity results in an affordable, reliable CNC control that will be productive for many years to come. Designed for small to medium sized machine tools, any machine that requires a 40 in-lb or less DC servo motor. The All-in-One-DC is perfect for bed mills, knee mills, small machining centers, lathes under 15hp, CNC routers of all sizes and many other types of machine tools. CENTROID CNC software for the All-in-One-DC runs on Windows 7 ,8, or 10 OS.
cnc control hardware video
"Allin1DC" CNC control system hardware overview video.
click here to see a detailed cnc hardware discussion covering the Centroid Allin1DC cnc control board and its related components and accessories.
All in one DC single board cnc controller for DC servo motors
click in image for larger view or click here to download PDF
CENTROID "OAK" CNC Controller, Simplified CNC one board does it all..
Use OAK based systems for all types of machine tools with any size AC servo motor.
Typical applications are Knee Mills, Bed Mills, all size Machining Centers, Horizontals, Vertical Lathes, all kinds of CNC Routers, Flat Bed and Slant Bed Lathes and many more. Yaskawa or Delta Servo motors are recommended.
Designed for any CNC machine tool needing large AC or DC servo motors, new Centroid "OAK" board yields a powerful yet flexible CNC control combination. Now you can easily interface to almost any make/model of servo motor and have the ability to integrate scales and/or encoders while controlling the spindle and any other accessory. This configuration is used in a wide variety cnc machines, everything from ultra precise bench top units holding micros to massive 20 ton horizontal machining centers. The OAK board is made in America backed by professional CENTROID CNC knowledge and support. Installers are available for on site installation on your machine worldwide. CENTROID's simple, elegant CNC control components are powerful and reliable. CNC controls available completely reassembled ready to bolt on or "board level" components for integration into your OEM product.
Single Board CNC Controller
click on image for larger view or click here to download PDF
- Replace your entire aging CNC control or reuse existing AC or DC servo motors that are in good condition.
- Use CENTROID servo motors and drives OR most any 3rd party AC brushless motor and drive pair.
Centroid CNC Hardware Video, Oak based cnc controller
"Oak" CNC control system hardware overview video.
click here to see a detailed cnc hardware discussion covering the Centroid Oak cnc control board and its related components and accessories.
Directly control your Fanuc Servo Motors: Red cap,Yellow cap and Black cap servo motors up to and including "20" size Fanuc motors. Up to 8 axes. CENTROID's new CNC CPU and our new AC/DC servo drive will command your existing servo motors. Eliminate expensive Fanuc repair costs and save time and get better performance with easier programming and operation. The CENTROID Fanuc Retrofit system brings an old machine tool back to a profit center for often less than the cost of repairing the old Fanuc control. call or click here for quote to upgrade a Fanuc based machine tool.
Fanuc Centroid CNC retrofit control system
click on image for larger view. or click here to download PDF
and don't forget to check out our retrofit image gallery showing many different types of CENTROID equipped CNC machine tools click here.
CENTROID UPGRADES for Older CENTROID CNC Controls.
Centroid supports its customers by offering affordable CNC repair and upgrade electronics.
Centroid has specifically designed the "Legacy Add" board to allow older Centroid servo based systems to be upgraded with a Modern Windows 7,8, or 10 CNCPC while retaining the original Servo Drives, Servo Motors, PLC and Power Supplies. Very little to no rewiring is required. The Centroid MPU11 CNC Motion Control Board with the Legacy Add card connects to the existing Centroid Hardware and runs the latest Centroid CNC software. call or click here for quote to upgrade an older Centroid CNC control.
Centroid CNC Control Upgrades for older Centroid CNC controllers
Turn-key ready to hang on the machine CENTROID Factory Prewire Allin1DC CNC Controller kits.
Allin1DC based CNC control systems for Machine Tools with DC servo motors from 7 in-lb up to 40 in-lb
Typical applications are Knee mills, Bed Mills, Small and Medium sized Machining Centers, CNC routers and Lathes.
Pre wired, tested, ready to hook up and run. download pdf
click here for hi res PDF
CNC Rotary Tables: True Simultaneous 4th axis CNC Rotary Tables
Ready to install on a Centroid CNC Control. Program with CAD/CAM, G code or Centroid's Conversational software.
CNC Rotary Tables true 4th axis
Yaskawa Servo Motors and Drive package pricing
Yaskawa Servo Motor and Drive Package Pricing.
click here to see Centroid Yaskawa pricing for common sized servo motors and drives.
Centroid CNC Options, Parts and Repair Price List
- Centroid CNC Accessories, Software and Parts price list
- Centroid CNC Probe Styli price list
Compliance with Export Control Laws for CENTROID products
- Compliance with Export Control Laws for CENTROID products document
- Written Assurance for export of software Assurance form
Site content ©2004-2015 CENTROID Corporation. All rights reserved. Terms of use.
