M-39
CNC Retrofit Control for Milling machines, Routers, Plasma, Water Jet, Engraving, Knee Mills.
Upgrade your machine with a CENTROID CNC retrofit and you'll save thousands of dollars in repair costs annually and significantly reduce machine downtime, eliminate expensive repair costs and make profitable parts quickly.
- Complete running CNC control system ready to bolt on a machine tool.
- 1 to 2 day install on most machines.
- Windows 10 OS, Ethernet connection between PC and CNC control.
- Fast, reliable Solid State Hard drive. (no moving parts)
- Prewired servo motors and encoders.
- Servo Motor Drive programmed and wired.
- Control Power supplies provided and wired.
- PLC pre-programmmed and wired, w/extra outputs.
- CNC PC w/software pre-installed w/fiber optic communication.
- Built specifically for your machine:
Motor sizes, cable lengths,
voltages, accessories cables, mounting hardware and more.
- Sealed electrical enclosure, prewired
tested and ready to use.
- Display and operators pendant mounting
hardware
included, multiple configurations
for custom applications.
- Lube,Mist, Flood,Vacuum, Spindle, and custom use contactors/relays
provided and wired ready to use*
- Remote operator control pendant, plug and play control of
spindle, jog axes, tool check, e stop, feed hold, coolant
- Pre-programmmed key functions for common machine tool operations
along with custom user defined key functions.
- User friendly Tool and Part setup menus.
- G code backplot graphics with time estimation.
- Money making options you can add at any time such as:
Digitizing, Probing, Auto tool measurement,
Coordinate System Rotation,
Work Coordinate Systems and more.
- Factory Tested and Run-in, ready for installation as shipped.
- One year warranty, on-site installation and training available.
Click here to Download the PDF brochure |
Start making parts now! Bolt on installation for both new and retrofit applications. |
The M39S now uses CENTROID's new ALLIN1DC CNC control card along with a new Windows10 All-in-one PC running our reliable CNC12 software. Now you get a big screen and keyboard with built in mouse pad and all the advantages of Windows 10 with all M39S orders with no price increase over the previous model. |
This new combination yields many advantages and useful tools to make your CNC jobs easier and faster to complete. In addition to all the great features of the CENTROID CNC software you get:
- Windows 10 familiarity for easy file transfers and networking
- Large easy to read display, (touch screen available).
- Run Windows compatible 3rd party software tools on the control such as G code editors, CAD systems, CAD/CAM systems etc.
- Use any PC compatible keyboard or mouse.
- Background editing, run another program while the machine is running a job
- Internet based remote control for fast accurate tech support - Fast reliable Solid State Hard drive (no moving parts) |
click on image for larger view... |
We build the CNC so you don't have to. Not just a box of parts or a software disc like the other guys, our CNC controls are ready to install on the machine, each M39 is custom built for your application, all servo motors, power supplies, PLC programming, CNC PC and Software are shipped assembled and ready to run. Get down to business fast and start making profitable parts right away, no other CNC control saves you this much time on installation. Since the M39 is a running CNC control as shipped, the installation is just a matter of bolting up the control, installing the servo motors, and connecting the power.
The M39 can drive either AC or DC servo motors up to 8 axes. The complete wired electrical enclosure can be mounted to the machine or with the CENTROID stand shown. Monitor and keyboard along with the pendant dock allow for easy machine adaptation and customization. Hardware provided makes installation quick and simple. The M39S CNC system is powered by standard 110 VAC or can be ordered in a high power version for 220 volt single or three phase or 440 volt phase input applications.
Useful
Tools for quicker job turn around. |
- Stop and
restart the job at any point.
- Stop, make
any adjustments, and restart right where you left off.
- Toolpath
Graphics show cutter path before & during the job.
- On-the-fly
override control of feeds and speeds.
- Useful Help
Screens guide you through Setup and Programming.
- Remote control
for fast job setups on large format machines.
- Run large
part programs with no limitations.
- High Speed
processing provides smooth machining, no gouging.
- Fast, smooth
continuous tool motion, no hesitation or dwell.
Dedicated
control panel for all common Milling functions |
- Remote control
pendant can be used hand-held or mounted.
- Clearly labeled
controls for each axis and direction.
- Dedicated
buttons for spindle and coolant controls.
- Spindle speed
override and Feedrate override.
- Tool Check,
Feed Hold, Cycle Start, Rapid override,
Incremental and Continuous Jog, Single Block.
- Customize
with Tool index +/-, Clamp/Unclamp, Vac on/off, & more.
- Extra auxiliary
buttons are programmable for special applications.
- Fully sealed,
coolant-proof, long lasting in shop environment.
- Tactile feedback,
raised buttons with distinct action.
- Indicator
lights show the selection made.
Conversational
Programming is fast and easy |
- Program parts
right at the control or offline with your desktop PC
- Centroid's
Intercon generates the G codes for you.
- Help screens
for all the common milling cycles,
just fill in the dimensions. Even lines and arcs are canned
cycles.
- A graph
of the part shows your work as you go. Graph your work at any
point, shows both cutter comp and programmed path.
- Automatic
pocket cleanout, Intercon auto creates the
roughing and finish passes automatically.
- Fill in
the blank programming.
Click here for more part programming info.
CAD to CNC, DXF
file import with Intercon Conversational.
Convert DXF files into G code with CENTROID's
Intercon conversational programming software. NO CAD/CAM system necessary.
Fast and simple, this new feature allows you to create parts directly
from a CAD file on the control or on your desktop PC. You can even
combine any or all of your CAD file with any conversational events.
This is the most flexible way to take advantage of both CAD/CAM like
programming with the simplicity of conversational. With a fast learning
curve anyone can be producing money making parts from a DXF file in
short order. This new feature saves you both time and money, less expensive
than a CAD/CAM system, much easier to learn with faster results.
Click here for more CAD to CNC info. |
view |
5
Axis CNC control. True simultaneous 5 axis machining.
True 5 axis machining is now available. Smooth consistent 5 axis motion.
Great for either gimble table setups or knuckle head machines. X,Y,Z,A
and B motion all at the same time or in any combination. For Milling
machines and CNC routers. Note: The M-39 can control up to 8 axes simultaneously. |
Auto
tool changer
The
CENTROID CNC control can operate a wide variety of types of tool changers.
Umbrella type to Swing arm -- the Centroid provides fast repeatable
tool changes. Automatic batch measurement is also available when used
with our TT-1 Auto Tool Setter. Just highlight the tools you would
like to measure and the batch feature will automatically retrieve,
measure and replace each tool automatically. |
Rigid
tapping, Deep hole tapping and Threadmilling
With
a CENTROID M39 you can make all kinds of threads.You can use Tapping,
Rigid Tapping and Threadmilling depending on your part for the best
result! CENTROID's advanced rigid tapping is simple to program and
will both tap a hole in the regular way AND can also use the deep
hole cycle to make a large diameter thread. Deep hole tapping taps a hole much in
the same way as you would by hand. It allows you to tap a much larger
hole than the HP of your machine would normally allow! |
Digitizing.
Turn your milling machine into a copy machine.
Copy
and Cut 2D and 3D shapes. Centroid's affordable, effective Digitizing
is the simplest CNC Digitizing on the market. Just record and play
back. Do you have a 2D contour such as a CAM or a 3D part like a mold
or plug? But no print? Let our Digitizing feature copy the part for
you. Digitizing turns your milling machine into a copy machine. Centroid
has overcome the cumbersome problems associated with Digitizing on
other controls. With a Centroid, it's actually one of the simplest
features on the control to use. With our Digitizing feature you will
be able to copy and reproduce an existing shape with little or no
programming! No CAD/CAM necessary, however you can export the Digitizing
information to a CAD/CAM system for further modification. It's very
popular for repairing cylinder head combustion chamber damage, copying
cams, creating molds and plugs from existing objects and many other
uses. more... |
Auto
tool set Setup
your tools in a quarter of the time it would normally take! If
you often machine short-run parts and are always setting up and
tearing down for a new job, the TT-1 Auto tool set will save you
tons of time while more accurately setting your tool height offsets.
With the TT-1 you can create more parts per hour since the tool
set up is so much faster. You'll even save time when you have
to replace a dull tool with a new one in the middle of a job.
The TT-1 is completely automatic. Press "measure" and
the tool will automatically touch off the TT-1 and set the tool
height offset in the tool library. See the TT-1 in action on our
Video CD. The TT-1 plugs into the control... |
Fully
sealed, coolant-proof Keyboard optional.
With
any CENTRIOID CNC control you can use a regular PC keyboard or our
fully sealed unit. We found that about half our customers prefer a
regular open style PC keyboard and the other half prefer a sealed
unit. The CENTROID sealed PC keyboard is liquid-proof and provides
reliable and durable keyboard operation in a shop environment.Our
keyboard is: fully sealed, coolant proof, long lasting in shop environment,
has tactile feedback, and has raised buttons with distinct action.
Click here for more info.. |
Retrofit
CNC Kits for Routers, Plasma, Knee Mills, Bed Mills and many more specialty machines.
Good
iron? Obsolete control? Time for a CENTROID Retrofit! Turn your Milling
machine into a money-maker with a modern Centroid CNC control. Our
complete turnkey retrofit systems are prepared for your specific machine,
making retrofit installation times much faster. Machining performance
is better than new, programming is now faster and simpler, and maintenance
costs are virtually eliminated. How much money per year are you spending
to keep your old control alive? Don't throw away your money when you
could have a new reliable Centroid CNC installed (with training) for
less than the cost to keep on an old CNC alive. The Centroid retrofit
upgrade is also much less than the cost of buying new.
Click
here for more retrofit information. |
Click here to download the M39 brochure in pdf. |
CENTROID
CNC Service and Support
Remote control from the factory, Skype video and instant messaging. Centroid
CNC controls have a proven reliable track record and offer cool,
quiet operation. Our controls are easy to maintain, with autotune,
dragplot and self diagnostics. Centroid CNC users are supported
by a nation wide network of local Factory Trained Technical
Representatives who provide fast affordable service, training
and upgrades. Centroid users can stay up with current technology
with easy Centroid CNC software updates. In just minutes, new
CNC features can be added to the control. |
Powerful
control with user-friendly operation |
- Cut parts
the first day with CENTROID's straight-forward operation.
- Machine parts
not possible with other controls.
- Get more
work through a machine with faster setups.
- Produce parts
with a better surface finish.
- Spend less
time programming and more time making chips.
- Bring in
more work and bid on higher paying jobs.
- Economical
control delivers the power and features.
- Easily customizable,
use any size display.
- Remote control
for faster setups.
- USB 2.0 and Ethernet Lan connection for easy file transfer.
- Use any Standard PC keyboard or fully sealed unit.
- Use any size LCD display.
