CNC Engraving: Engrave Letters, Numbers, Symbols
Centroid recommends using a CAD/CAM system to generate G-code for engraving. There are many good choices these days for CNC engraving such as Fusion 360, Vectric Cut 2D and Vcarve Pro, Millwrite, and many others. Centroid's G-code smoothing feature compliments Engraving Gcode allowing Engraving programs with short vectors to run smoothly.
CENTROID recommends Vectric Engraving software for all types of CNC engraving
CUT2D
Cut2D is used to convert CAD DXF and graphics designs into GCode / CNC Toolpaths for machining parts and components. Priced for the entry level user, Cut2D is affordable, easy to use software that's very functional and creates high quality CNC toolpaths for virtually all types of CNC machines.
VCarve Pro
VCarve Pro is a powerful, flexible industrial strength software package that includes all the design, layout and machining functionality demanded by commercial shops and users, while remaining incredibly easy to use and affordably priced. VCarve Pro is a complete solution For CNC routing, sign making, woodcarving, and engraving.
****Vectric software runs on a Windows based PC. Newer CENTROID CNC controls that use Windows 10 or 11 as the Operating System can now run Vectric software directly on the CNC control. (Note: Vectric software still works with older CENTROID control systems as well, you just can't run the software directly on the CNC control, you'll have to use a desktop or laptop windows PC to run the engraving software).
