Centroid Allin1DC CNC Control Installation Videos by Marty's CNC Garage
Allin1DC project overview
Marty gives us an overview of the Allin1DC CNC retrofit project machine
Building a computer for CNC use
Marty shows us how he built a PC for CNCPC duty that meets the Centroid Minimum PC performance requirements. A step by step video showing the CNCPC build
DC Servo Motor encoder upgrade
Marty shows us how he upgraded the servo motor encoders on the existing DC servo motors that came with the machine for better performance
Bench Testing the Allin1DC CNC Controller
Marty shows us how to follow the Allin1DC installation manual and bench test the Allin1DC before installing in the electrical cabinet
Preparing the Machine tool and electrical cabinet
Marty shows us how he has prepared his machine for the Allin1DC installation. Limit Swtiches.
Electrical Backpanel Install: Part 1
Marty shows us how he installed the electrical cabinet back panel
Allin1DC CNC electrical system schematic explained
Before starting wiring Marty explains how to use the Centroid Allin1DC CNC system schematic
Wiring subsystems, Intro and Tools: Part 1
Marty explains rotary on off switch, estop contactor, dc power, logic power, output relay use, useful tools to have for this project
Electrical Backpanel Install: Part 2
Electrical Backpanel Install: Part 3, Sinking and Sourcing
Marty shows us what Sinking and Sourcing is all about
Electrical Backpanel Install: Part 4, E-Stop Circuits
Marty shows us how to wire up the Estop circuits
Electrical Backpanel install: Part 5, Wiring the VFD Circuits
Marty shows us how to wire up the Variable Frequency Drive (VFD) circuits
Electrical Backpanel install: Part 6, Wiring the Flood, Mist, and Limit Switch
Marty shows us how to wire up the Flood, Mist, and Limit Switch circuits
CNC Software Initial Configuration: PID, Estop, Limit and Encoder testing
Marty shows us how to setuip the Centroid CNC control initial configuration for PID, Estop, Limits and Encoder testing
Servo Motor Runaway Explanation
Marty explains why a DC servo motor will run away if it is wired wrong
Servo Motor preliminary testing and belting to the machine
Marty shows how to test and belt up the servo motors to the machine
Axis direction explained
Marty shows us the proper setup of Axis direction movement
Properly reversing servo motor direction explained
Marty shows us the properly swap axis movement direction
Setting up Home Switches and Homing the machine off switches
Marty shows us how to setup home switches and get the machine homing off the swtiches
How to determine accurate Overall Turns per inch (Fine DRO Adjustment)
Marty shows us how to set up the overall turns ratio accuracy (how many turns of the motor yeilds one inch of table travel) of the machine using precision guage blocks
Setting Up Software Travel Limits
Marty shows us how to set up the software travel limits
Parking and Shutting down the CNC control and machine
Marty shows us how to use the shut down features of the Centroid CNC control
Centroid CNC Systems Test
Marty shows us how to run through the CNC Systems Test to make sure the machine is ready to make parts
Allin1DC CNC control retrofit upgrade project wrap up video
Marty gives us a wrap up history and overview of his Allin1DC CNC control retrofit upgrade project
Cutting first Job with the Allin1DC retrofitted machine
Marty shows us how he uses the newly updated allin1dc cnc knee mill to modify motor mounts for his next retrofit!
CNC Mill Training Video
This is a older CNC mill operator training video. While it may be old, most all of the video still applies to today's CNC controls. So forgive the references to "floppy drive" and learn from the rest.
CNC Mill Training Video: Knee Mill Tool Height Setup
This is an older training video, but setting up Tool Heights on a knee mill hasn't change. Setting Tool Height Offsets with a reference Tool explained.
